EJ_Allmota | EJ1 Reincarnation
Old 04-18-2014, 03:23 PM
  #51
EJ_ALLMOTA's Avatar
Default Re: EJ_Allmota | EJ1 Reincarnation
UPDATE: Ive started reassembling my front suspension.. Still need to order some new brake rotors since the ones i had were completely rusted, also I need to order front sway bar end links for my ITR sway bar.. Also I just got my engine bottom end parts back from the machine shop.. Bottom end is now balanced, crank shaft was polished, Supertech 12.4:1 compression pistions were mounted on shot peened LS rods and 10lb flywheel was balanced..
DSC_1879 by Khris H., on Flickr
DSC_1863 by Khris H., on Flickr
DSC_1894 by Khris H., on Flickr
DSC_1907 by Khris H., on Flickr
DSC_1919 by Khris H., on Flickr
Old 04-18-2014, 05:16 PM
  #52
eric26x's Avatar
Looking nice!! Car came a long way
Old 04-23-2014, 01:50 PM
  #53
ez_
ez_'s Avatar
Oh, man...! Never thought I'd live to see THIS comeback!
Good to have you back in the game, specially with the second version of the snow white, Khris! The first one was a major inspiration and now that my EJ1 is back to bone stock, will be checking this new build for sure.
Keep it up, man!
Old 05-04-2014, 10:56 AM
  #54
EJ_ALLMOTA's Avatar
Keep it up, man!
Glad to hear it man, I always get a great sense of accomplishment hearing that others were inspired by my old coupe..
Some new parts arrived Thursday morning and I decided to refresh an old one to suit the current colour scheme..
Brand new slotted rotors for all four corners
DSC_2018
Front sway bar endlinks for my ITR sway bar
DSC_2029
Painted the inserts to match my my engine bay and inside of the car..
DSC_2019
Old 05-08-2014, 09:00 PM
  #55
EJ_ALLMOTA's Avatar
Rear suspension put back together.. Cell phone photo.. ASR Brace, Function From Type 1 coilovers, Function Form LCA and ASR 24mm sway bar all installed..
20140503_234227
Old 06-05-2014, 08:29 PM
  #56
EJ_ALLMOTA's Avatar
Took a better image of the suspension setup.. Currently working on the wiring.. elimating what I will not need..
DSC_4940
Old 06-16-2014, 11:53 AM
  #57
EJ_ALLMOTA's Avatar
Separated my headlight harness and ran it through the fender rails.. Didn't really plan on tucking anything but since I had the harness all apart from removing all ABS wire, I thought why the hell not..
All ABS wiring removed
Headlight harness tuck
Almost forgot I only had two of my Rota Slipstreams polished.. Back to work i go on the other two.. 800grit was done, got started and finished on 1000 grit (all by hand)..
Before 1000 Grit wet sand
After 1000Grit
After 1000 Grit wet sand
Old 06-19-2014, 10:25 AM
  #58
Squidette's Avatar
i'm loving this. in for progress
Old 06-28-2014, 07:45 PM
  #59
EJ_ALLMOTA's Avatar
Never planned to go too crazy with clearing out the engine bay, mainly just focused on cleaning up wires so I with that being said I re-installed my stock brake lines..
No brake line tuck for me
No brake line tuck for me 2
Old 07-17-2014, 09:16 AM
  #60
EJ_ALLMOTA's Avatar
Installed my ITR brake booster, S2000 Clutch Master Cylinder as well as installed my Integra Type-RX pedals that ive had for over 6 years..
Making progess
New pedals
1000 Grit result
Old 08-16-2014, 07:31 PM
  #61
EJ_ALLMOTA's Avatar
Finally got my hand back on a Canadian cluster.. 140 mph, Km/h large and mph so I dont have to do too much thinking on how fast Im going in mph if I had a JDM cluster..
DSC_1027
DSC_1033
Old 08-27-2014, 02:48 PM
  #62
EJ_ALLMOTA's Avatar
Just some updates....
Re-installed my fuse box as well as separated and re-wrapped my engine harness plugs.. Headlight, AC and horn wires are now ran through the inner fender..
DSC_6280
Integra Type-RX pedals installed..
DSC_6272
Upon attempting to re-install my climate control air boxes I noticed that the foam that helps route the air from the boxes to the vents were just about non existent.. I decided to get some weather stripping and fix create a proper seal so that air isn't just being thrown under the dash and are actually making its way to the vents..
DSC_6305
Air boxes almost completely re-installed, just one left to do..
DSC_6299
Old 08-27-2014, 03:21 PM
  #63
sixstroke's Avatar
What kind of paint did you use on your block and tranny?
Also, what kind of under-coating?
Thanks bro, keep it up!
Old 08-27-2014, 04:53 PM
  #64
Skip01's Avatar
Digging this
Old 08-27-2014, 06:31 PM
  #65
EJ_ALLMOTA's Avatar
Its funny for the block and trans I was going to paint them silver but when i painted them with primer i liked the colour and just decided to keep it primer and clear coated it.. As far as the under-coating its Rust-Oleum Rubberized under-coating..
Originally Posted by Skip01
Digging this
thanks man..
Old 08-30-2014, 12:20 PM
  #66
joey1320's Avatar
Great work bro!
Old 08-31-2014, 09:39 AM
  #67
Danger's Avatar
Nice work, getting close.
Old 09-04-2014, 09:49 AM
  #68
Axix24's Avatar
Get rid em rotas plz..
Old 09-04-2014, 06:02 PM
  #69
EJ_ALLMOTA's Avatar
Originally Posted by joey1320
Great work bro!
Thanks man, im trying..
Thanks man, yea it is and i cant wait..
Thanks for the advise.. lol...
Old 09-16-2014, 06:58 PM
  #70
EJ_ALLMOTA's Avatar
I decided since I'm looking to start putting my motor together id make a slight upgrade.. My last Vtec head was quite noisy with my Skunk2 Pro1s so to avoid that again upgraded my Lost Motion Assembly especially since I will be running Pro2s in this head.. Picked up the Skunk2 Lost Motion Assembly..
DSC_6478
DSC_6486
DSC_6487
Old 09-16-2014, 07:08 PM
  #71
HT's TOP CHEF
Chef Andre's Avatar
Great progress man!!!! Nice to see you back and looking forward to dyno numbers on that motor. I need to do my fender wells on the crx. What did you use top clean it all before you sprayed the rustoleom? I was thinking of using that por15 cleaner.
Old 09-16-2014, 08:04 PM
  #72
EJ_ALLMOTA's Avatar
Thanks Chef.. I just just some degreaser and a scrubbing brush, lol.. I have heard good thing about that Por15 though.. My homie teg97 used it on his ITR build..
Old 09-20-2014, 08:29 AM
  #73
teg97's Avatar
That POR15 degreaser and metal prep does work wonders.
Old 09-21-2014, 02:56 PM
  #74
ez_
ez_'s Avatar
Helluva work, Khris. Just a question: how much time do you spend in a week working on the EJ?
Old 10-10-2014, 10:00 PM
  #75
EJ_ALLMOTA's Avatar
Thanks a lot man.. I usually try to work on it at least once a week but I doesn't always work out that way since its housed at my homies shop..
Finally got around to installing my dash board and installed a Walbro 255 fuel pump.. Will hopefully start working on my fuel lines tomorrow..
DSC_0003
Quick Reply: EJ_Allmota | EJ1 Reincarnation
