Build up of 97 integra gsr-redjet:)
#176
Re: Build up of 97 integra gsr-redjet:)
dang dang has it been along time that i haven't posted anything new and geez i looked at the last pics i posted i think i have came along way from that point.
New things done to the car now
Brake system is installed,rear brake,front and lines,gotta get a type r brake booster yet
intake manifold is on
most of the coolant hose are hooked up
interior of the car is mostly put together now
Front sway bar is hooked up
fuel system is installed
fenders installed
front bumper
The brake lines in the older pics that i made arent not the ones i used,i ended up buying OEM brake lines there is noting better then OEM!
ill post some pics of where i am at now and you can get the idea.
Brake fuild and Hawk pads
I made new wires to the starter being i put the batt in the trunk
cleaning under the intake manifold
Had to add a spacer for the fuel rail with RC injectors
fenders installed
front bumper
#177
In this update there is no pics,but if you look in the last pics i posted i mounted the fuel filter and FPR right to the fuel rail and i do not think that is safe way to roll on track being it might shake lose and crack the rail.i would rather not see a fire happen.I am redoing that as we speak.
I been cleaning odds and ends of the car up and checking off things to make sure they are tight and TQ to OEM spec.
I will post new pics of the fuel setup when i have that done and whatever else i find to do.
sander
08-22-2009 05:08 AM
phamily
07-01-2009 12:06 AM
