Would b18a piston rings work on b16 PR3 pistons?
I was thinking instead of milling my head, put in some PR3 pistons to bump up the compression in my b18a.
Now I have brand new hastings rings for the b18a pistons but was thinking if they would work on a PR3 b16 piston. My guess would be yes since the pistons are pretty much the same except for the dome on top to raise the compression, but I would like to check here before I would even go and do it. |
Re: Would b18a piston rings work on b16 PR3 pistons? (Mr.RHTuner)
Yes, all B rings are the same
not b20 and yes u can use ls rings on a gsr pistons or b16
Re: (b16coupe4)
awesome.
Thanks for the info guys https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images...es/emsmile.gif |
Re: (Mr.RHTuner)
Using a different piston is better than milling. You can put the stock pistons back in but you can't replace the milled head material. Plus it does not mess up your cam timing. Dan
Re: (Dan Ruddock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan Ruddock »</TD></TR><TR><TD CLASS="quote">Using a different piston is better than milling. You can put the stock pistons back in but you can't replace the milled head material. Plus it does not mess up your cam timing. Dan</TD></TR></TABLE>
I have a few b18 heads to use so i wasn't worried about that https://honda-tech.com/forums/images...s/emsmilep.gif but thanks for the response man https://honda-tech.com/forums/images...es/emsmile.gif https://honda-tech.com/forums/images/smilies/emthup.gif |
