Whats wrong with this engine???
lock
Re: Whats wrong with this engine???
Thats just oil burning off of the header in the video.
are you sure your not off a tooth on the timing belt
any smoke coming out the exhaust? do another compression check and see if it lowered any
Originally Posted by FLATBUSH PROJECTS
(Post 43340708)
what injectors? stock?
Check for any major vacuum leaks? |
this may sound ridiculous but I also had a similar problem try rechecking the vacuum diagram for the egr solenoid and the feul pressure regulator. Those two are usually close together and get mixed.
Stock 01 itr injectors.
No leaks. |
Did something very similar with my y8, i had the IACV plug mixed with one of the other ones, swapped them and ran just fine.
Iac is plugged in correctly.
http://C:\Users\Turbomx-6\Pictures\vacuum diagra.gif the mix up on mine after the new engine swap was vacuum hose 16 and 24 where mixed. The small stuff sucks
I said injector cause I had a similar problem with mine and they were not getting enough fuel to the cylinder holes although I had full compression, fuel pressure etc. The ONLY way i got my car to run and drive was to hold the throttle open and to get it in for tuning full throttle just to go 40mph. IMO sounds like its lacking fuel.
When I prime the motor the fpg reads 42, then reads 0 after it stops priming. Should pressure remain in the line?
Yes u should have constant pressure. Now after about an half hour it should bleed back down to 0 psi. But not within a 5 minute window.
Looks like from the vid that ur valve seals on the exhaust side could have taken a shit on u and possibly be fouling out that cylinder b/c u can clearly hear a distinctive misfire. It's gotta be that or a slightly bent valve or for some reason the timing isn't set right. Question y do u have the camgears at -2 , and + 2 u should try 0 and 0 and see if that works better cam gear tuning should be done when the car is running perfect or if the cams have been degreed.
Before I did the valve adjustment the fuel would read like you said, dropped to 0 after awhile, I noticed that after priming it there was no pressure.. This could be a result of poor seals? The cams were set before I installed the motor, and supposedly was running fine.
leakdown test
Have you checked your fuel filter, fuel pump and fpr? is your system grounded? If you had bent valves it would be smoking like a chimney and be missing TERRIBLY. It sounds to me like a mix of no fuel and poor timing.
Originally Posted by allmotaR
(Post 43346112)
Bent valves
timing sounds off like by 2 teeth or somethings wrong with your ign system.. that sounds godawful. |
I got a map for you to try if you'd like to try it... running a stock oem map is stupid and dumb and using a chip that isn't made for your car is dumber.. i have a tuned setup i did a few months back i can send you the bin.
that sounds.. awful. |
double check everything i want pics of the cam gears being lined up,
Adjust your cam gears too btw.. you should leave your gears at 0/0 i'm pretty sure you may have slightly bent a few valves. |
OH HEY TRY THIS lol. This happen to me this year putting my motor back together it was missing horribly. Ur injector seals check them spray water around the injector seals a little bit not alot and see if the motor changes tune. That will make the motor out of time b/c of a vacuum leak for that runner.
^ I'm assuming I would put water around where the injectors meet the manifold or the rail?
(Post 43351917)
