vtec engaging twice
recently i noticed that my vtec engages,drops and kicks back in right away.
not every time i only heard it 3 times the oil pressure is always at 70-80 doesnt fluctuate much oil is halfway between marks ive used 0w30 since it was first started |
Re: vtec engaging twice
Have you taken it off to see if there is any shavings/gunk in there? What RPM's does it fluctuate, and is it consistent?
it kicks on momentarily then back off and on and it stays on till redline.
not every time tho |
Test the vtec solenoid or pressure switch? could be taking a dump...
Is it the motor in your sig? |
Lucky
yep it was all cleaned up when bult there wasne even metal shavings on the magnetic stick. but never know one migt have slipped by.
make sure oil pan is not dented in to where the oil pickup can not pick up enough oil.
What rpm does it kick on
5500
the car was tuned |
