Touge Monster - H23A VTEC EG6 by RGHTBrainDesign
#26
Re: Touge Monster - H23A VTEC EG6 by RGHTBrainDesign
#27
As you can tell in his pictures though, it's a tight fit.
#28
I much prefer a B-Series Transmission to the K offering. Clutch is B-Series and cheap. Pilot bearing area on crank snout needs modified, but otherwise it's all B-Series Driveline with nothing crazy out of the way. Rice Brough is awesome. His kit and K to H Intake Manifold adapter made this whole thing a breeze.
#29
Thanks Chance EG, I'll do some searching and digging around. I am sure there is lots of topics on the K vs H2B here just need to search them out. But it was sort of what I was trying to get at. Was looking to do something new on the EG since I've worked on my fair share of B's in the past.
#30
I would have to say that H-Series is cheaper in stock trim, but getting it all properly swapped and built NA, the k24 is actually a more economical swap. Downside being a less tactile cable shift linkage transmission.
I prefer my setup due to timing belt, cam gears, etc all still being manual labor to adjust. It's just a more raw experience that teaches you more about the internals of engine construction, design, and tuning. The K-Series is refined and FAR easier to tune efficiently with power, almost zero compromise (VTC ftw!).
#31
Biggest problem with the H, in my opinion/experience, is the FRM sleeves (which I think is what you were getting at). Can't reliably put in aftermarket pistons without sleeving the engine, and once you consider the cost of an H2B kit/swap plus the cost of sleeving, as you said, a K24 becomes more economical. The choice between H2B or K just depends, as everything does, on what the ultimate intent and goal of the car is.
Good steel shift cables with spherical bearings can help the shifter feel significantly, along with a good shifter box. Huge improvement over the OEM, makes it feel almost identical to the B linkage.
I'll stop derailing things now. This is a great build, and I'm glad to hear it's effective at doing what you love and that you enjoy driving it.
#34
Is your block sleeved or are you still using the frm sleeves?
What advantages do you feel your k series manifold have versus aftermarket k series manifolds and h series manifolds?
#35
Ahh, well, I went from a Hybrid H22 Prelude setup with IAB and IACV on the head side (for clearance issues), right into the CTR RRC w/ added plenum volume (0.35L) to somewhat match the displacement for the engine and maximize length within the engine bay. The setup also jumped from 64mm OEM TB to 72mm KTuned Billet TB, so again, none of my experiences were apples to apples here. My buddy Elvis Lee (SBSPerformance) could tell you that the Ultra Series (K-Series) whoops some serious ***, but my favorite all-motor canyon setup would likely be 90mm KTuned TB + RBC + Added Plenum Volume. I went with 72mm for better throttle control as I'm not seeking power so much as control.
What I did learn was that drivability has not suffered, but that came hand in hand with learning to tune the car every few days over the last year. There are thousands of Hondata saves for this configuration, but I'm still not perfectly content. I'll get drunk and bust out the laptop once I throw on the new TB tomorrow and figure out ideal transient fueling from idle to 3k, which is really where I'm least refined out of everything. That's where I can tell you if I think the IAB setup actually had more torque (it doesn't).
Overall, this configuration is netting me an average of 26mpg mixed driving with Bay Area traffic, 85mph highway driving, and some tire roasting fun. I have a good 4-5mpg improvement on the way once I refine that hanging idle and lean out transient fueling. In the canyons, I'm hoping to have 22mpg. Really doesn't go lower than 20, even if I'm constantly beating on it. Gotta love the efficiency of it all.
#36
I had a request to show off the Denjis, so here we go...
Just put on these Vision replica corner lights and they're terrible... The bulbs will fall right out. *Facepalm*
Anyways, I figured out a nice pattern for the headlights, but I just need to refine the High Beams (give them LEDs or HIDs and AIM them properly!) and add another relay so I can do "flash to pass" without disabling the low beam. Both of these lights on together are a force to be reckoned with.
#37
This is still a relatively LOW compression setup and would love boost if I had the room for it. - It's the factory FRM Sleeves with seemingly zero oil burning. Given the fact that I had to run a thicker headgasket, I'd say I'm around 10.2:1 Compression with this RLZ Head. I have about 1000mi on the Civic since we threw it all together and tomorrow will be the first time draining the catch can. Cold start, hot start, etc are always clear of any coloration, and my tuning on the motor without IACV is good enough to where remote start works any time of year due to proper ignition, intake temp, and coolant temp compensation tables.
https://www.youtube.com/watch?v=AvhHOS6Rg34
#38
Today I finished up the 72mm TB Install w/ IACV, different catch can/vent configuration, started fresh on the tune, and adjusted the Denjis to be MUCH better.
High Beams
Low Beams
High Beams
Low Beams
#39
Nice build RGHTBrianDesign
H23A and the internet famous "G23" use the same crank. It's also the same crank found in the not so famous SOHC F22A/B....:0.
There is an actual G series Honda engine though. It is an inline 5 that came with a 2.0L or 2.5L displacement. In that case, nether of the G20A or G25A cranks will fit in an I4 H23A.
#40
There is a G series Honda engine though. It is an inline 5 block that came in ether a 2.0L or 2.5L displacement. In that case, nether of the G20A or G25A cranks will fit in an I4 H23.
#41
The 97mm F23A crank has 55mm main journals, so if I am not mistaken it will fit the JDM H23A VTEC. However, it will not fit the US H23A1 with 50mm mains, at least not without line boring the mains anyway.
#43
Just a quick update with where this car is headed:
Bachelor Party Roadtrip
https://binged.it/2JNOeJg
- KW V3s Finally Shipped from Germany
- ASR 1" Swaybar - 3/29
- Front HardRace LCAs w/ Moog Outer Tie Rods (ESM Race are NOT an upgrade IMO) - 3/29
- Final Cowling Installation w/ New Honda Clips and an additional leading edge lip to compensate for shrunken cowling - 3/29
- Alignment - 3/29
- Prep Interior, Shave Expandable Foam from Previous Owner, and Sound Deadening Paint & Sound Deadening - 3/30
- Headunit and Audison Prima Components - 3/30
- 13.5 Gallon Gas Tank Upgrade - 4/5
- Extended Front Fender Brackets and Fender Rolling - 4/6
- Carpet Installation - 4/12
- Install KW V3s and Alignment - 4/13
- Final Prep Before Roadtrip with Damper Setting Optimization - 4/19
- Picking Up Black Interior in LA and Bachelor Party Roadtrip - 4/26
#45
Nice pic of the ride <thumbsup> on a side note what are your plans for the fuel tank upgrade you mentioned above?
thanks man!
thanks man!
#46
thanks man!
thanks man!
#47
Yeah figured you were driving it some distance to keep the storage that high. I was planning on the opposite and looking into weigh savings while upgrading the entire car since its really old and was from a rust state (Ohio). So far the only one I really found was the FCS unit 5 gallon tank, think it weighs like 8lbs or something like that. Trying to get this puppy as light as possible during this restoration build process. Think their 7 gallon tank is like 11lbs but they want $800 for it. Seems like the factory replacement ones can be had for under $200 bucks too. Also got rust around the fuel intake section of the tank under the rear quarter so tossing the idea of getting a tank re-routing too without doing the labor for fixing it....**** doesn't end...
#48
Think about it this way, pump gas weighs about 6.3lbs per gallon. You're not saving much weight. Don't kill yourself over it... Just drop in a Spectra H09 like what I picked up and extend capacity to 51L (13.5 Gallons).
Today was successful.
MOOG Tie Rods, Hardrace Front LCAs, ASR 1" Rear Swaybar, adjusted door strikers, inspected all front suspension, and centered steering rack.
Plenty more to do tomorrow, but I'm feeling ahead of schedule considering how good the car drives after everything.
#50
The whole trip down to LA/Big Bear is going to get filmed on various action cameras and such, and I'll throw down some fun vlog content if I get the chance. Epic Driving Roads, here we come!
Thank you for the compliment. She's running better than ever too. If I have time before the trip, I'll rent out some dyno time and really find MBT throughtout the map on this unique setup.
