Built For War - Race Spec EG Hatch by RGHTBrainDesign
Nothing special, just a car tailored to my liking for my specific usages.
Chassis
Engine
Induction
Exhaust
Chassis
Interior
https://cimg5.ibsrv.net/gimg/honda-t...0a4832dce7.jpg https://cimg7.ibsrv.net/gimg/honda-t...fd93c1e5d2.jpg https://cimg5.ibsrv.net/gimg/honda-t...b1a0ec67bf.jpg https://cimg9.ibsrv.net/gimg/honda-t...2a1db4df0e.jpg https://cimg1.ibsrv.net/gimg/honda-t...09a993c2d0.jpg https://cimg3.ibsrv.net/gimg/honda-t...3672ab7349.jpg https://cimg7.ibsrv.net/gimg/honda-t...62b508360b.jpg https://cimg4.ibsrv.net/gimg/honda-t...475337767a.jpg https://cimg1.ibsrv.net/gimg/honda-t...8f478a1bff.jpg https://cimg3.ibsrv.net/gimg/honda-t...65b6a7d29d.jpg https://cimg5.ibsrv.net/gimg/honda-t...52da021cd7.jpg https://cimg6.ibsrv.net/gimg/honda-t...68cf516838.jpg https://cimg5.ibsrv.net/gimg/honda-t...c5006e3e4b.jpg https://cimg0.ibsrv.net/gimg/honda-t...094c55009f.jpg https://cimg7.ibsrv.net/gimg/honda-t...2ed854b789.jpg https://cimg8.ibsrv.net/gimg/honda-t...a01a1d7f34.jpg https://cimg8.ibsrv.net/gimg/honda-t...3d14c3964e.jpg https://cimg7.ibsrv.net/gimg/honda-t...00708471ab.jpg https://cimg9.ibsrv.net/gimg/honda-t...0c9dff95f4.jpg https://cimg0.ibsrv.net/gimg/honda-t...797ce08c96.jpg https://cimg3.ibsrv.net/gimg/honda-t...3a2947c246.jpg https://cimg4.ibsrv.net/gimg/honda-t...8eb865f7c4.jpg https://cimg5.ibsrv.net/gimg/honda-t...ea60a8fcd3.jpg https://cimg2.ibsrv.net/gimg/honda-t...0e7971cd3e.jpg https://cimg3.ibsrv.net/gimg/honda-t...0d91bb1e09.jpg https://cimg5.ibsrv.net/gimg/honda-t...2a36874e69.jpg |
Re: Touge Monster - H23A VTEC EG6 by RGHTBrainDesign
Dig the oil cooler, what type of set up is that? Like it good bad, etc? Have been wanting to put together my own oil cooler kit versus buying the off the shelf ones for like $500.
Looks great, I just saw the thread in the intro section and had to follow it here, so glad to see more info. From the build I can only venture that it is an absolute torque beast.
All the pictures still have a dist, have you had it up and running on COP yet? |
I'll have to watch the videos after while. I enjoyed the ones you did on your integra. This makes me interested in an h2b setup again.
A lot of stuff is getting done this weekend.
Next weekend is COP, finalizing Cruise Control, Installing KW V3s, etc. If not, it won't be far off. All the videos are of this similar drivetrain setup in the Integra. Hopefully y'all enjoy it. There will be plenty of EG6 videos when I feel the car is ready. We've built this thing to such a high caliber in such a short period of time. |
Originally Posted by OGNAEG
(Post 51890917)
Originally Posted by snobordboy
(Post 51891087)
As of right now, the car is +/-2% fueling throughout the entire rev range in Open Loop, all load conditions (not just WOT). The street tuning I've been doing is pretty incredible. 3.2k RPM and 3rd Gear on relatively grippy 205/50-15s = wheel spin when floored. It's a fun car. Can't wait to show Yall the planned upgrades being installed. |
Originally Posted by RGHTBrainDesign
(Post 51891371)
Read the breakdown above. ;)
(Post 51891387)
my my bad I must have skimmed over it just saw it now will look it ip later today and check it out |
Man, these H2B setups leave the engine crammed against that driver's side frame rail. Beautiful build, for sure.
I'm interested to see what you do with the AC compressor, and that part of the setup. |
spec looks solid, except no AKMEE parts LMAO. otherwise good.
Originally Posted by exgr
(Post 51891611)
So a few of you might be wondering what this car is all about... Here's the rundown:
Checked out the oil cooler, looks like the core you can get for less then $100 then there is the lines and oil filter attachment. Good alternative to buying off the shelf for $500. I am always interested in piecing together some that is just as effective for $500 but for $200-300 bucks. I was planning on running a tucked radiator which it seems this oil cooler might be able to sit underneath it since I plan on making changes to the lower radiator support bar (cutting the OEM lower piece and making my own that bends slightly lower then oem). Any opinions or thoughts on oil cooler setup that you wouldn't mind sharing? Wondering where your oil line links up into the oil cooler or if you ran it oil out around the motor and then oil back in around the other side vs both lines running the same side of the engine (in and out). Thanks man! like your set up! <thumbsup>
(Post 51891874)
*Earl's 19 row oil cooler *Mocal sandwich plate on OEM oil filter w/ 0.5" to -10AN adapter fittings *-10AN stainless lines *-10AN Fittings fitted to top of oil cooler ( only should be mounted vertical or 90* angle, and never inverted) I only have one photo recently done as I move the car from storage to my house. Intercooler removed https://cimg3.ibsrv.net/gimg/honda-t...5bbf933efa.jpg Oil cooler shown on lower right side by windscreen fluid reservior |
Shodan, thanks for sharing man this is useful for me getting some ideas to put together my own oil cooler into my EG. Piecing it together seem like a much better idea then spending the 500 bucks for off the shelf kits. The oil cooler core you put in seems to be like 80 bucks new online assuming the lines and fittings were about 100 more would you say. I was planning on putting the battery in the location where you currently have your oil cooler which is why I was looking into a unit that is more wider in nature like the one posted in the original post. Some units out there have fans attached to them too, any thoughts on that?
(Post 51892043)
Also, put the battery on the other side or relocate it to the trunk if you must move it. I placed that cooler in that location to get the most air available. If this is a civic chassis, even the side frame behind the radiator support (as long as it is below the oil filter of the block) is a more optimal location than what you may be thinking initially. I don't use any fans, as my cooler has ample access to cold air rushing through. If you have the right access to air, it will flow faster than any fan could provide. keep that cooler low... |
Derale has a setup that I'd run here if I didn't already use the FC configuration.
Derale Oil Cooler Fabrication costs alone we're over $500... You get what you pay for. Between the bumper support trimming and holes, threading a location stud, L-brackets, line shortening (from the 34 Row setup), figuring out vibration isolation, and the final fit and finish to force the bumper as a proper ducted unit, this was 3/4 of a day's work with two people on it. This has always been a "Gotta Pay to Play" game. Nothing good in life comes easy. You should focus on what you really want to do and either work harder for it, or focus on something else. Now, let's get back to my build... |
(Post 51892163)
Derale Oil Cooler? Fabrication costs alone we're over $500... You get what you pay for. Between the bumper support trimming and holes, threading a location stud, L-brackets, line shortening (from the 34 Row setup), figuring out vibration isolation, and the final fit and finish to force the bumper as a proper ducted unit, this was 3/4 of a day's work with two people on it. This has always been a "Gotta Pay to Play" game. Nothing good in life comes easy. You should focus on what you really want to do and either work harder for it, or focus on something else. Now, let's get back to my build... |
Thanks for the link and agreed lets get back to your build my bad to take it off topic. Appreciate the input.
Originally Posted by TheShodan
(Post 51892188)
understood, however, that is ridiculously large and unnecessary for that sized engine. You'd be adding over double the oil for that to work., if you and I are seeing the same thing here. (Unless your link was just an example of what you're considering on a smaller scale?) :shrug:
Here's that 34 Row Oil Cooler on my Canyon-Spec Integra:
https://cimg6.ibsrv.net/gimg/honda-t...754ce003bc.png Here's more detail on the FC Oil Cooler work... It's extensive: https://cimg4.ibsrv.net/gimg/honda-t...225e36d2a2.jpg https://cimg7.ibsrv.net/gimg/honda-t...98877f2aca.jpg https://cimg5.ibsrv.net/gimg/honda-t...841fe97465.jpg https://cimg1.ibsrv.net/gimg/honda-t...88f369a834.jpg https://cimg5.ibsrv.net/gimg/honda-t...62646c992e.jpg |
(Post 51892222)
Well, I suppose it's dependent on your usage. To me, I'm driving my car out in the mountains all day long and some days are more humid than others. There's no such thing as too much heat exchange (when it's thermostatically controlled). Altitude also has a huge factor as air is thinner and the efficiency in which heat exchangers do their work decreases the higher you go... Again, none of this is overkill, it's necessary. Do it RGHT, Do it Once.
So, just curious your decision making process on going H2B. Took a 20 year hiatus since my last hatch and just looking at different options in terms of swaps. Done my fair share of B's over the years and just curious your thoughts.
