timing question
Old 08-20-2007, 07:31 PM
be8teensee1's Avatar
Default timing question
i have an ls/vtec swap , gsr head. what is the timing specs ? should i run it at 16 degrees btdc or is it ok to go to like 18 ?
Old 08-20-2007, 08:37 PM
Default Re: timing question (be8teensee1)
gfsdjg
Old 08-21-2007, 05:07 AM
IntegraType-R's Avatar
run stock, 16 tdc thats your best bet, a few people run 18, but it depends on the deck height and etc, do u have any slack in your gear's if so, you might have to advance to compenstate for any head milling or height difference.
Old 08-21-2007, 07:27 AM
Default Re: timing question (IntegraType-R)
[QUOTE do u have any slack in your gear's .[/QUOTE] do you mean the belt?
Old 08-21-2007, 07:31 AM
ya.
Old 08-21-2007, 07:48 AM
there's a little bit
Old 08-21-2007, 08:06 AM
well u need to make sure u adjust that slack out, possible. Um, was the head milled any, whats the layers of HG are u using, etc etc.
petarr
04-07-2006 10:11 PM
rabbid1
08-16-2004 05:02 PM
Batoutahell
08-06-2004 12:47 PM
vtecmike1
05-13-2004 08:25 PM
CRneXt
05-01-2004 06:14 AM
Quick Reply: timing question
