Built B20Vtec or Built Type R?
I am considering two different motor setups and I'm having trouble deciding which route to take. I currently have a 2000 B18c5 in my EG and was thinking of just sticking with the Type R and do some head work to it (valvetrain, P&P, etc....) My other option is to get a b20 block with high compression pistons, and also do some mild head work to the Type R head. What do you guys think?
Re: Built B20Vtec or Built Type R? (gsxryder415)
you already have the type r so id just stick with that and build it..u can sleeve the b18 to a 2L instead of buying the b20 block
Stick with the R, get a good header, port the intake manifold, and valvetrain/m22 or blox b camshafts.
Oh yeah, maybe a 2-layer gasket and flat faced valves for a tiny bump in compression.
Finally, most important get it tuned.
Modified by mar778c at 10:32 AM 6/14/2006
I have a B20VTEC setup now but if you already have the C5 and it's running, why change it up?? stick with it and build it up slowly...it's more cost effective
