Skunk 2 Tuner2 camshaft - is the use of "quick settings" beneficial?
I have a 98 spec jdm itr with two layer hg and tuner2s. Cams are not degreed in. When i did timing belt after changing the hg it ended up being a tooth off. Im going to do the timing again and see if i can get it dead on.
I am planning to dyno tune car, but really am lookin for some quick settings to try to save time on the dyno. Head is not shaved and block is not decked, just two layer hg.
Thx
Thx
re: Skunk 2 Tuner2 camshaft - is the use of "quick settings" beneficial?
^^Agreed get the motor in time and set the cams to 0 degrees, let the tuner make the call from there.
When I degreed them on my gsr I ended up with +1 on the exhaust and +3 on the intake. It made good power on the dyno but I heard from a couple of knowledgeable people here to start retarding the exhaust cam and see what happens. Ended up retarding the exhaust 6 degrees on the dyno and made a pile of power in the midrange and up top. Actually went seven but dropped the engine vacuum and power and went back to 6. End settings were -5 exhaust and +3 Intake.
That's ALOT of separation. Good to hear though. Wish we could see an overlay of the graphs.
Im not going to be going back to the same dyno so numbers are going to be a little skewed, but car was running consistant 13.4-13.5 at 99-100mph in a 94 integra
The Tuner series camshafts like overlap(Advancing Intake, Retarding Exhaust). These camshafts work well with this type of cam gear setup.
Car ended up making 218hp 147tq on mustang dyno using hytech/dtr side exit header and 3" race intake goin out headlight with velocity stack. Going to be a couple weeks before i can get car to the track to back up those #s
we adjusted cam gears to +2 intake and 0 exhaust, tuner said without measuring valve to valve clearance he wasn't comfortable going any further. i wanted to advance intake a lil more and try retarding exhaust some but car made good power so I didn't push the issue.
stock jdm itr bottom end with 2 layer hg-approx. 11.3-11.5 compression
96 spec itr head with alpha springs and retainers itr valves, skunk 2 lma, skunk 2 tuner 2 cams
itr intake manifold with 70mm alpha throttle body port matched to im
3" custom 42" long intake tube with vibrant velocity stack
hytech/dtr side exit header with megaphone
rc 440 injectors
rc 440 injectors
I tuned a b18c today with tuner2 cams.
Specs:
wiseco 81.25 11.6 cr pistons
manley rods
untouched gsr cylinder head
tuner 2 cams with supertech springs
plm header
in +2 and ex -2 cam gears tuned on dyno 219whp 150wtq
with stock camgears 215whp 140wtq
here is the you tube link with cam gears tuned
oem camgears
Specs:
manley rods
plm header
oem camgears
