Safe RPM with b16a2 stock bottom end
Hi,
What do yo uthink are safe rpm for stock b16a2 block? Head is p&p, milled, with toda cams and bc valvetrain. Now I'm going to tune it with crome and am wondering how high can I set the redline. Will 9k rpm be ok? thanks |
Re: Safe RPM with b16a2 stock bottom end (easy_rider)
ten million thousand hundred fifteen RPM's!!
j/k https://honda-tech.com/forums/images...s/emsmilep.gif |
Re: Safe RPM with b16a2 stock bottom end (2000turbogsr)
i wouldnt rev more than 9.5k
9k is safe in my books, my b16a has been to 9k numerous times and was running strong until the day it came out of my car. Good luck!
Re: Safe RPM with b16a2 stock bottom end (Brad Stubbert)
I want to say 9k and you should be good. Hell, they're made th run high
Ok, i'll go with 9k then. Thanks and fingers crossed https://honda-tech.com/forums/images/smilies/emwink.gif
i ran my b16a3 with crower stage 3 cams and dual valve springs to 10k all day every day so at least 10 if not more!
