b20 vtec all motor build
so im doing a b20vtec build and i found a jdm b16a head with ctr valve springs ctr valve cover bbk intake manifold pretty much a fully built head but im concerned about how im gonna build the bottom end.....and should i use my ls block i have laying around or my current running motor in my car.....it will be mated to my ctr trans......btw this will be my daily and i know this has been covered but what ecu should i run and will i need a hondata s300?what pistons and rods should i run....what crank should i run....stock b18b1 crank?cash isnt to much of a concern because i will be buying one part at a time till i have all of the stuff to build it all at once!!!!
Re: b20 vtec all motor build
yeah that setup sounds real fast i got a b20v setup with gsr head n stage 1 cams n bolt ons and runnin a p28 and beatin new si's n dc5s type s 06 n etc k20 swap teggys etc
look no need to get hostile everyone im just 17 and little new to the scene even though ive did my research im just wandering whats a good setup is all......so lets keep this thread friendly k thanx
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-build-%22reliable%22-lsvtec-b20vtec-1676914/
^^^ very true You guys must do some type of research before you get into your build. Check my build thread on my b20 vtec...
mattymickc
06-14-2017 04:10 AM
xEnderx
07-28-2005 07:41 AM
