RDX injector hats/injectors
I just got my injector hats adapters for the RDX injectors I'm going to install into my b-series motor, now when I install the hats onto the injectors do I need to remove the hook on the RDX injectors to make it sit right, or just leave it on?
Re: RDX injector hats/injectors
What do you recommend?
I was wanting to do 55psi for a base pressure to get a better atomization, which these come stock on the RDX right?
Now forgive me for be such a noobie I'm still learning, any info will help me, if the 255lph HP will fine on my bulid let me know, I have a freshly build motor with a CR 11:5-11:9, I thought these injector would work great, a price that can't be beat.
Btw I will post up pics of the hats on the injectors.
This info is all over the internet if you do a search........All the formulas to calculate fuel pump flow rate in conjunction with injector flow rate are all out there as well. Some just need the air plane spoon every now and then.
i run 190lph + rdx injectors
i have a b&m fuel pressure gauge at idle i get 49psi and wot around 58psi
i know that these gauges may be a little off btw...
i would choose 255lph you get 70-75psi on these.
If the aftermarket caps are made correctly the RDX injector with the cap installed should be the exact dimensions of your OEM injector, No other modifications required to the fuel rail or rail attachement hardware.
Nice setup, I actually just got the RDX injectors with the tophats as well, but they are not installed yet, waiting for my fuel rail. Anyway my question was after you installed them, how did they fit? And do you have a picture of them installed?
Steve at Heart
<p>@Johncivic3</p><p>Do you realize this thread is three years old? Probably not going to receive much of a response from the OP.</p><p>I have these installed in a H22 Skunk2 manifold with AEM rail, K-Tuned adapters and they fit fine though. Only picture I can find below.<img src="http://cimg0.ibsrv.net/gimg/honda-tech.com-vbulletin/1024x576/80-20150402_152046_zpshd7bnhnj_35fc41b9022880a95a61c6 8595c9d949474e17e0.jpg" title="" /><br /> </p>
Old or new I appreciate your reply, I am bow to install them in my B18 and I haven't seen any videos or pictures of anyone else that did this mod, i've known it's not a new thing and ppl have been doing the mod but haven't seen any one post it until I seen your post.
So thanks for replying..
