oversized valves, p29 pistons, mini me
Setup is d16a6/zc block, with d16z6 head, p29 pistons
will there be piston to valve clearance problems with .5mm over valves? people say the valve releifs are huge on p29 and you can run any cam, then others say itll hit? i understand to get the best answer i should clay the motor but id like feed back from people who have done this type of build before thank you |
Re: oversized valves, p29 pistons, mini me
I know everyone hates sohc but bump
Which cam are you running?
Originally Posted by turbo1.5
(Post 49603322)
Originally Posted by JDMequalslife
(Post 49602804)
i understand to get the best answer i should clay the motor |
