►Official All Motor Dyno Thread!
#1476
Premium Member
Re: ►Official All Motor Dyno Thread!
Not surprised by your comments about the lack of numbers. A couple of things: The Mugen Twin Loop you will lose power with one of those. Get the rest of the Toda System. You did no air improvements to your head. When you do you'll be looking for about 141 in Flow Numbers. With your CAI get an Ingen. I've seen 15 to 25hp with those. Surprisingly awesome for a bolt on. I de-tuned my NA, removed the Ingen and went back to a MS sucking off the Screen because I had a chassis imbalance (which is now fixed).
#1477
Re: Official All Motor Dyno Thread!
Head p72 stock, 11.0.1 piston, skunk2 tuner 3 cams, intake skunk2 pro, throttle 68mm, b20 84mm, header plm Tri y big tube 2.5
this is my setup who can help me with the problem, I thing that make 220hp
#1479
b16b block
81.5mm 5cc Wiseco pistons
GSR Crank (87.2mm stroke)
Eagle Rods (138mm)
Supertech 85 lb springs
Skunk2 Pro 1+ Cams
Mildly ported head (done by local machinist)
OEM b16a valves
OEM timing belt
OEM head gasket
1320 SMSP-style headers
60mm mandrel bent exhaust with Borla ProXS
Injen CA Intake (probably 2.25" or 2.5")
OEM b16a intake manifold and throttle body
211.5 whp @ ~7800 rpm142 lb ft @ ~7400 rpm
Eagle Rods (138mm)
Skunk2 Pro 1+ Cams
OEM b16a valves
OEM timing belt
OEM head gasket
#1480
^Very nice, I'd cut redline at 8500RPM though.
#1481
Premium Member
Looking at the Torque I'd change gears at 8000. You would have a very handy over rev to put a pass on someone close to you. Plus you are not going any faster beyond 8. Still quite good numbers indeed.
#1483
Thanks everyone! Ya, I'm pleased with the level of power that this makes on pump gas with the parts I have at the moment. The tuner recommends a better flowing IM, TB, and intake for more power. Also e85 as 12:1 is a little high to be fully taken advantage of on pump gas.
As to the rev limiter, my ideal is to have the rpm within peak power after I shift to the next gear, so I like having maybe 1500-2000 rpm or so higher than peak power if I can.
#1484
Car: BB9 Prelude
H22A Type S engine
Euro R pulley
Ebay air filter
Jdm BB6 Type s Throttle body
1320 performance Tri-y 2.5 collecter, 2.25in system
Ukdm Accord Type R tranny
Jdm BB6 Type s Gear set
Spoon chipped P13
203bhp
164whp
152ft/lbs
Last edited by StndMnky; 02-16-2019 at 09:25 AM. Reason: Mistake with exhaust system size had to edit correct diameter
#1485
Low cam
Final pull.
B16 head
S2p2s
Full s2 valve train
Victor x
Dsm 440s
Itr rep header
B20b block
Bone stock.
A set of $68 bearings
250kmi rings.
242whp
157 ft-lbs
Choked out up top from the small header just installed a set of big tubes and some ignition upgrades will be making another go here soon.
#1486
Final pull.
B16 head
S2p2s
Full s2 valve train
Victor x
Dsm 440s
Itr rep header
B20b block
Bone stock.
250kmi rings.
242whp
157 ft-lbs
B16 head
S2p2s
Full s2 valve train
Victor x
Dsm 440s
Itr rep header
B20b block
Bone stock.
250kmi rings.
242whp
157 ft-lbs
#1488
since so many people are running sk2p2's I have blox p1's and there close in specs do you all run sk2 lost motion or stock?
#1489
I'm running the SK2 LMA with my Pro2s. I mainly made the change when i was building the head due to the fact i know how noisy the factory ones get when they are worn out..
#1490
Since Skunk2's LMAs are not available for the H22, I e-mailed them asking if OEMs would have any issues with the Pro 2s I got for my build. The exact reply I got from Douglas Haley at Group A Engineering (Kraft Werks/S2/Grams) was: "Yes, the OEM LMAs will work the the Pro2 cams."
Cross-referencing part numbers at the OEM parts sites, part# 14820-PCB-305 is listed as compatible with a '96 Prelude Si VTEC, '99 Civic Si, and '98 Integra GS-R. However, the '98 ITR uses part number 14820-P73-J01; not sure what that's about. No part number is listed as available for the fifth-gen Prelude. Also, doing a quick Google I'm finding decade-old forum posts talking about shimming required to use an H LMA in a B; anyone know what that's about, if they're the same? I've heard that it's recommended you install new LMAs any time you change cams, even for same-spec OEM if you did that for whatever reason, especially if your engine still has the old piston style installed.
#1491
#1492
#1493
Haven't posted in a while. Recently got my engine retuned after ECU swap. I will post the dyno graphs when I get them in a couple days.
Here are the engine specs.
B18C
EK9 pistons
Skunk2 Tuner 2 cams
PWJDM intake
Hytech headers
Amuse exhaust
Link ECU
199whp
140trq
B18C
EK9 pistons
Skunk2 Tuner 2 cams
PWJDM intake
Hytech headers
Amuse exhaust
Link ECU
199whp
140trq
The following 2 users liked this post by beat:
#1494
B18C
EK9 pistons
Skunk2 Tuner 2 cams
PWJDM intake
Hytech headers
Amuse exhaust
Link ECU
199whp
140trq
https://youtu.be/LUXIl8AcKDo
B18C
EK9 pistons
Skunk2 Tuner 2 cams
PWJDM intake
Hytech headers
Amuse exhaust
Link ECU
199whp
140trq
#1495
Stock 84mm bore
arp bottom end
Stock rods
RS itr piston
B16 head
Bad Guys stage 2 port package
Supertech flat valves
Rocket m24xx cams
Rocket springs
Ported skunk2 ultra street
70mm tb
Aem hybrid cai
plm sp tri y header
2.5 mandrel bent exhaust with 22" resonator and 26" muffler routed oem path (VERY quiet, catches everyone off guard)
Tuned on e85 by MNTuning at Race FWD, dynojet on winpep 8 software.
221 hp / 148 tq @ 8300 rpm
arp bottom end
Stock rods
RS itr piston
B16 head
Rocket m24xx cams
Rocket springs
70mm tb
Aem hybrid cai
plm sp tri y header
#1496
91 si hatch
engine
jdm b20b (low comp p3f piston) stock block
p8r head (stage 2 ported by badguys)
skunk2 IM (also ported by bad guys)
rocket motorsports stage 4 cams
rocket motorsports hd valve springs
arp head studs
70mm tb
ebay intake w/velocity stack
dsm 440’s
str fuel rail and adjustable cam gears
91 oct
tuned on neptune
198.8 whp. Non vtec. Stock block
engine
arp head studs
70mm tb
dsm 440’s
91 oct
tuned on neptune
#1497
Car got tuned today. Really happy with the numbers and power curve. 184.7/123.5
97 Civic DX
B16B, no PS no A/C
Refreshed bottom end: Kings coated bearings, ARP rod bolts, Nippon Rings
Valve job, stock replacement valves (not sure of make), new valve guides, Nippon leakless HG
Icebox Intake
PLM Power Driven TA/Toda replica
PLM test pipe
Apexi WS2 catback
GSR Injectors, Fuel Rail & FPR
Walbro 190lph fuel pump
93 octane
Otherwise stock
Tuned w/ S300 by Mike @ Syn Garage
97 Civic DX
B16B, no PS no A/C
Icebox Intake
PLM test pipe
Apexi WS2 catback
93 octane
Otherwise stock
#1498
100% internally-stock B16A3
Comptech replica header
eBay 3" intake
Test pipe
Skunk2 Mega Power 60 mm exhaust
Coil-on-plug conversion
Link G4X plug and play tuned on 93 octane by George at H-Car in San Antonio
155.1 WHP / 114.2 ft-lbs
Baseline on Hondata S300 and stock ignition was 137/99 on the same dyno. Next mods: Toda header (already installed, post dyno session), Spec A cams, valve springs, cam gears, Blox LMAs, and a re-tune.
eBay 3" intake
Test pipe
#1499
Car looked great at the dragon meet. Nice numbers on the b16 as well!
eBay 3" intake
Test pipe
eBay 3" intake
Test pipe
#1500
Beautiful EF, very nice.
