octane fuel recommended
which ocanage fuel recommend to a B-18 c6 with RC 13:1
thanks |
Re: octane fuel recommended
Your querry and info given is so vague.kindly expound more.
i don,t speak English, I am using the translator , that info are needed?
for 13:1 af you can use 110 octane.
pentru 13:1 af poti sa folosesti 110 octane. |
some kind of intake is to reduce the RC
can work with 106-octane fuel and methanol injection
that's abit excessive don't you think? just got my 12.5:1 tuned on the dyno on 93. made good power also.
106 will be OK
be sure you have good tune. Do you have Ethanol (alcohol) in your country? |
12'5:1 on 93 octanos ? my tunner says that with this compression is needed racing gasoline
yes have methanol |
100 octane is good up to 14.1 after that u have to use 110
Your tuner should talk to your engine builder.they should know better..there are alot of ways to run any octane around that CR or vice versa.
I am the builder but in my country is the first time you assemble this RC on a street car and tunner does not have much experince with this RC
I could send a map to see it? thanks |
Are octane rated with the R + M/2 method in your country or do they use motor only? That is going to make a big difference in the numbers you guys are throwing around.
the difference between your gas and ours is that of ROM is here and yours is POM
calculate how could I know half to another? |
