Help! Ebay'd Again!
Old 03-31-2009, 08:37 AM
EKJOE's Avatar
Default Help! Ebay'd Again!
Hey guys....I dont know why I keep doing this to myself, But im done now...Promise.
I ordered a set of 81.25mm p30 pistons and rings from Ebay member "FOREVERJDM" heres what they sent me.
Piston Part # P30-000
Rings Part # PR3-003 (USDM?)
The pistons are 81mm standard bore and the rings im confused on, .3 over size? They are for a 81mm piston but would have to be file fitted?.
Either way, these guys ****ed me. Their communication is virtually non-existant. I just filed a dispute with paypal over the whole thing.
Here's my question. Who knows the Honda part #'s of the 81.25mm p30 pistons and rings?
I just want to make sure I buy the right parts this time.
Old 03-31-2009, 09:12 AM
EKJOE's Avatar
Default Re: Help! Ebay'd Again!
Please dont make me beg guys, or **** I'll even go with aftermarket 81.25mm, Any suggestions?
Old 03-31-2009, 09:40 AM
GhostAccord's Avatar
What are the first 4 digits of the part number? They indicate what size pistons and rings you have. For all OEM Honda Pistons
13010-***-*** = STD Piston
13011-***-*** = STD Rings
13020-***-*** = .25 OS Piston
13021-***-*** = .25 OS Rings
Old 03-31-2009, 09:44 AM
EKJOE's Avatar
Pistons: 13010-p30-000
Rings: 13011-pr3-003
Old 03-31-2009, 09:47 AM
ruffrhyder's Avatar
Take a picture of the boxes for both the pistons and rings. For example when I ordered RS machine pistons that were 81.5mm or .020" oversized the box said 81mm but in the bottom right hand corning it said .20 which meant they were .020" or .5mm oversized.
Old 03-31-2009, 09:49 AM
EKJOE's Avatar
Naw dude...These are stock bore....My machine shop measured the diameter of them and they have my block already bored to 81.25mm, So its set in stone these are wrong.
The only other numbers on the boxes are these.
Piston: G7K09
Rings: 8C24
Old 03-31-2009, 09:51 AM
Yup you got OEM stock bore pistons & rings with those numbers.
B16A1 0.25 OS;
13020-P30-G00 = .25 OS Pistons
13021-PR3-003 = .25 OS Rings
Old 03-31-2009, 09:53 AM
EKJOE's Avatar
Thanks Ghost. What does the 003 represent? as opposed to say 004?
"the 003 to 004 is most likely the "generation" replacment. 3's are probably older than the 4's" Is this correct?
Old 03-31-2009, 09:57 AM
004 = Manufactured by Teikoku
003 = Manufactured by Riken
Old 03-31-2009, 10:07 AM
EKJOE's Avatar
Thanks Ghost...Time to go buy the right **** now
Old 03-31-2009, 10:31 AM
EKJOE's Avatar
Ok who knows a reliable place to buy the set?
Old 03-31-2009, 10:34 AM
ef1.8's Avatar
your local honda parts counter?
or Steve at hmotors online
Old 03-31-2009, 01:43 PM
ruffrhyder's Avatar
Piston: G7K09
Rings: 8C24
I wouldn't trust a machine shop that overbores a block without the pistons.
Old 03-31-2009, 05:19 PM
QuickStyle's Avatar
x2.
Old 03-31-2009, 05:45 PM
88Hatchy's Avatar
http://www.raceaxis.com/performance-piston-c-1_732.html
Old 03-31-2009, 07:42 PM
ruffrhyder's Avatar
You'll probably need these .5mm overbore since the machine shop already bored the block without the pistons so in case they went wide with the bore you'll need to go another .25mm overbore. Or contact this ebay seller if he has a 81.25mm set.
http://cgi.ebay.com/ebaymotors/RS-MA...spagenameZWDVW
boostedb20z
02-10-2008 12:38 PM
b20vtech
05-10-2007 06:23 PM
crex23
02-02-2006 05:41 PM
ssr_h22
09-06-2004 09:21 AM
Quick Reply: Help! Ebay'd Again!
