My 2.3 liter B
#404
Re: My 2.3 liter B
Brad is definitely the man. I'm not shooting for 300hp but love your build and gives me hope for my setup here is my link to my build. Any feed back would be great
https://honda-tech.com/all-motor-nat...er-3s-3263049/
From those two pro 2s
#405
Re: My 2.3 liter B
I'm running a Skunk2 ultra race intake manifold now. 4.5 liter and the ultra 90mm tb. I'm going to stack a 2.0 spacer on it and make it a 6.5 liter. And we are cnc porting the manifold runners to match the head.
#411
Re: My 2.3 liter B
how has the bearing life been on the rotating assembly? my buddy and i where gone do the low bugget version b21 crank and rods and cp custom pistons for a 2.1 liter but was told its hard on the rod bearings. this is one of the nicest peace of work ive ever seen. so u did 310 with ur old head on the 17.5;1 2.3 bottom end then tagged the valve and put your new head on and made 332?? what fuel are u on now still e98?? also back in 2011 when u had the fuel problem which pump did u switch over too? aem ? aeromative?
#412
Re: My 2.3 liter B
I run a A1000 and VP M5 now. And not had any bearing issues as of yet. And my compression is down to 14
5.1 / 15.1 right now fixing to cut the new head to bump it back up.
#413
Re: My 2.3 liter B
awesome numbers sir for 86x98 =D! do u never tryed a big cams "STILL 3 LOBES" like tb3 or some customs like web cams or the new ultra 3 and different header like sheepey built or TB? what is the flow on your head too?
#414
Re: My 2.3 liter B
I am in the process of trying to get a new header and some bigger cams now. Plus porting the manifold runners and making the plenum bigger as well. And will be flow benching the head to.
#417
Re: My 2.3 liter B
Okay cool. Which rod though, LS or gsr length?
The reason I ask is, Im wanting to do a 98mm stroker and I already have LS length rods. If those will be okay Im going to do 98mm, otherwise Ill probably go 95mm with long rod. I just cant find any info on the rod length used on a 98mm stroke or if the LS length is okay or not. I know the 2 rods are only 1mm length difference, but I don't know how much of a difference that will make.
I do appreciate the help.
#418
Re: My 2.3 liter B
Type in the Big end width of the crank you're using in Google. That's what I did. From there search around
#419
Re: My 2.3 liter B
I don't know the big end width of that crank. I don't have it yet. Id be ordering the scat light weight 98mm crank. If you know it, please let me know and that will determine which rod will fit on it.
#421
Re: My 2.3 liter B
Scat cranks are set up to run a LS/B20 rod with a big end width of of .935in
