LS crank and rods in a GSR Block? Is it possible?
#353
#356
re: LS crank and rods in a GSR Block? Is it possible?
The gsr block has oil squiters and ls internals have oil galleries
Do they both do the same job? If not explain?
I see either can be retained 1 with minor mods the other with stock internals
With forged internals in mind why wouldn't i need the oil squiters since i think they dont come with any other way to lube the piston and piston wrist pins?
#358
#359
Sorry to bring this thread back from the dead just getting mixed conseptions & dont know what I should do. I have a fresh gsr block thats been bored to 81.50 to fit my FORGED cp 11.0.1 pistons I have both cranks for a gsr & LS I also have NEW eagle rods for LS & GSR Should I go ahead with LS crank LS rod swap in my block or not ? I dont like the fact of bending the squirters at all I heard that forged pistons dont need them anyways so I can just cap em off with Golden Eagles kit but then again I put 15k+ on my car a year & beat on it pretty good. I guess u can matching .075 off crank weights or something, but will this affect the balance of the rotator assembly Im going to have whichever balanced regardless, again I have 2 sets of crankshafts as well as Eagle rods so Ls set-up & Gsr all redely available
#360
Moderator
Stop worrying so much. It's been done quite well, with a lot of longevity. My wife has had hers 2 years with the B20 Crank/rods, Endyn Pistons, GE oil squirter block kit, ARP studs and main bearing kit.
Here's an example.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/project-em1-shodan-goes-na-2458563/
Enjoy it.. its fine.
Here's an example.
#361
Here's an example.
https://honda-tech.com/forums/showthread.php?t=2458563
Here's an example.
#362
If you use the LS/B20 rotating assemble, get it balanced and use a GE block off kit. I have over 120k miles now since my GSR with LS internals build. I had the car dynoed about a month ago and managed 190whp with bolts ons and M22x cams (cam gears untuned), and that was through a 2" collector and stock cat. Hoping to make 210whp with a 2.5" collector mods and high flow cat and some cam gear tuning.
#363
#364
Here's an example.
Here's an example.
#365
Wow thats comforting to hear thats a lot of mileage lol do u think I should re-tang my LS h-beam Eagle Rods or are LS bearings sufficent enough ? hmm I guess when they say when u go forged u dont have to have em what do you think about endyns theory about running an external oil line similar to ls vtec to keep the cams/valvetrain cool ? Good insurance or overkill for a daily
On the external oil line, I guess it's just added insurance for the valvetrain, but I'm not sure what it will do to oil pressure. Where is the oil line plumbed and directed to? I would call Endyn and get their expert opinion on the matter.
#366
all mtr teg is the man, I'm still in the air between a b20 and gsr block with ls crank but the more I read about your setup the more I think gsr block with ls crank and a 75 shot is the way to go.
#367
I just like the comfort that the block was designed from the factory to accept 8500rpm plus the fact that I dont have to run lz/b20 vtec oil line or mess with dowel pins decide which h/g to get There are plenty of reliable B20vtec builds I just have 2 complete GSR engines ASWELL as a b18b It would be nice to have the b20 torque I hope to acheive the best of both worlds its killing me to have all these parts sittting in my bedroom & garage my car pulls hard now but I know with my new pistons race head BPI k&n set-up aswell as free er flowing exh I estimate my hp to be just shy of the 220 mark made 208hp with stock JDM gsr piston unported head & bottlenecked exh to muffler & had Apexi power intake/competech ice box set-up
#368
if you left the oil squirters would it make it an ls vtec? or to have an ls crank in a gsr do you have to plug the oil squirters?
#369
You dont have to run squirter block offs when running an LS/B20 crank in GSR/ITR block but you have to bend the squirters out of the way or the crank will hit, its not a good idea to plug the squirters if your running cast pistons ie oem HONDA ITR etc, But encouraged for forged pistons I plugged mine because I have Forged CP pistons/Eagle rods, when you plug the squirtes it bumps the oil pressure higher elsewhere, Its not really an LSV because have a block girdle etc. With my bore/stroke im like a b19vtec lol
#371
Moderator
The depends upon the compression you want. Stock LS pistons would only give you 9.2:1, and assuming you want to be in the all-motor forum, you want a bit of compression. Aftermarket is the way to go. But PCT pistons are out of the question.
#372
ok thanks so should i buy b18a/b or b18c aftermarket piston because there's the ls crank n rods in there? or there the b18a/b and b18c aftermarket pistons are the same height and everything?
#373
Moderator
The difference is in the deck height. When you look for your Pistons, find the ones that are for B18a/b with B16 head or GS-R head. They are typically the same part numbers as the others, but the compression changes a little bit. you'll see that in the charts. For Wiseco, the ones I used were K566M815 (I believe that was the part number). But I liked wiseco's the best.
#375
Bringing this thread alive again. Great thread..doing the same work on my brothers car and learned a lot...So how are peoples motor running, with or without oil squitters...and so on.
