Let's see your 1.8L OEM Bottom-end, ALLMOTOR, 91 Octane Dynos
#26
Re: Let's see your 1.8L OEM Bottom-end, ALLMOTOR, 91 Octane Dynos (6ghatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6ghatch »</TD></TR><TR><TD CLASS="quote">B18c5 block with 81mm CTR pistons (standard bore)
B16a2 head with valve job and some mild exhaust work
OEM head gasket
Mugen Oil Pan
Mugen Thermostat
Buddy Club stage 4's
Buddy Club cam gears
Rocket Gen2 springs and Ti retainers
RC 370cc injectors
OEM ITR TB and intake manifold
Toda header
T1R test pipe
RM-01A exhaust
Password JDM power chamber intake
B16a2 tranny
Quaife LSD
4.9 ATS F/D
Toda Flywheel
Exedy organic clutch
CTR N1 crank pulley
Hondata S100
mild tune with 12.5:1 A/F on pump gas
Modified by 6ghatch at 7:33 PM 7/19/2005</TD></TR></TABLE>
good HP gains but low torque
OEM head gasket
Mugen Oil Pan
Mugen Thermostat
RC 370cc injectors
Toda header
T1R test pipe
RM-01A exhaust
B16a2 tranny
Quaife LSD
4.9 ATS F/D
Toda Flywheel
CTR N1 crank pulley
Hondata S100
#27
OEM head gasket
Mugen Oil Pan
Mugen Thermostat
RC 370cc injectors
Toda header
T1R test pipe
RM-01A exhaust
B16a2 tranny
Quaife LSD
4.9 ATS F/D
Toda Flywheel
CTR N1 crank pulley
Hondata S100
seems like your numbers are a little low you should have over 200whp you might want to look into a new intake mani and throttle body and id bet youd hit the 200 mark real quick also with some more tuning
OEM head gasket
Mugen Oil Pan
Mugen Thermostat
RC 370cc injectors
Toda header
T1R test pipe
RM-01A exhaust
B16a2 tranny
Quaife LSD
4.9 ATS F/D
Toda Flywheel
CTR N1 crank pulley
Hondata S100
#28
Re: Let's see your 1.8L OEM Bottom-end, ALLMOTOR, 91 Octane Dynos (LG_R32)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LG_R32 »</TD></TR><TR><TD CLASS="quote">
seems like your numbers are a little low you should have over 200whp you might want to look into a new intake mani and throttle body and id bet youd hit the 200 mark real quick also with some more tuning </TD></TR></TABLE>
I need to run the OEM Intake manifold and Throttle body for my race series, Honda Challenge. Also, JE's dyno is setup to read on the low side, the numbers would be about 5+% higher on a dynojet.
#29
I need to run the OEM Intake manifold and Throttle body for my race series, Honda Challenge. Also, JE's dyno is setup to read on the low side, the numbers would be about 5+% higher on a dynojet.</TD></TR></TABLE>
are you allowed to have your throttle body maxbored and your intake manifold ported
#30
are you allowed to have your throttle body maxbored and your intake manifold ported </TD></TR></TABLE>
nope, unmodified OEM parts.
#31
Re: Let's see your 1.8L OEM Bottom-end, ALLMOTOR, 91 Octane Dynos (ALLMOTOR18)
us itr swap blue line untuned. vafc set 0,0 5700 vtec. red tuned 6300 vtec
skunk stage 2 cams/springs/retainers/gears/mugen headgasket/aem shorty intake/rsr exhaust/smsp header...kenji ecu/vafc hack....stock headcasting/stock block
#32
Re: Let's see your 1.8L OEM Bottom-end, ALLMOTOR, 91 Octane Dynos (Y2K Si FBP)
GSR block and head..no port
81.5mm SRPs
forged rods
balanced/micropolished crank
dual valve springs
ti retainers
peak cam gears
hondata intake manifold gasket
cometic head gasket
supertech hicomp valves
dynamic stage 2 cams
comptech ice box
itr arm
itr t/b
dynamic intake manifold
dynamic header
test pipe
apex piping (not 2.5 inch)
es oval
honda S200-p28
190 fuel pump
RC 310s
81.5mm SRPs
forged rods
dual valve springs
ti retainers
peak cam gears
cometic head gasket
comptech ice box
itr arm
itr t/b
dynamic header
test pipe
es oval
honda S200-p28
190 fuel pump
RC 310s
#34
81mm bore B18A1 Block
USDM ITR Pistons
89mm stock LS crank
LS rods with ARP rod bolts
CTR Crank Pulley
OEM Headgasket
Unported GSR Head
Portflow Valve-Job
Omnipower Dual Valve Springs, Ti Retainers, Flat Faced Valves
BC 3+ Cams
AEM CAI
Skunk2 Intake Manifold
Hondata Intake Manifold Gasket
ITR throttle Body
SMSP Header
2.5" Custom Exhaust
Magnaflow Race Series Muffler
RC Eng. 310cc Injectors
Walbro Fuel Pump
Hondata S200
Motul 300v 5w-30
WITH A CAT!!!!
USDM ITR Pistons
89mm stock LS crank
CTR Crank Pulley
OEM Headgasket
Unported GSR Head
Portflow Valve-Job
BC 3+ Cams
AEM CAI
ITR throttle Body
SMSP Header
2.5" Custom Exhaust
Walbro Fuel Pump
Hondata S200
Motul 300v 5w-30
WITH A CAT!!!!
#35
Re: (LsVtec92Hatch)
94 JDM B18C
Stock bottom end
Stock head
CTR intake cam
Skunk2 intake mani
Ebay cold air
4-1 header w/ 2.5" collector
Omni 2.5" test-pipe
Espelir cat-back
Mugen chipped P28/ untuned
186whp/136tq Dynojet SAE corrected
Don't have a dyno sheet but this should be proof enough. 4th gear pull
http://www.we-todd-did-racing....DE%3D
Modified by ChaseIntegra at 8:53 AM 7/25/2005
Stock bottom end
Stock head
CTR intake cam
Skunk2 intake mani
Ebay cold air
Omni 2.5" test-pipe
Espelir cat-back
#36
just out of curiosity for all those who posted dyno sheets. what gear where your pulls made in 3rd or 4th.
#39
is there anyone out there running a Daily Driven Jun or Toda cam setup out there w/ any dyno sheets/track times????
#41
I dont have a dyno handy.
But 204/141trq
B18c1
CTR Pistons
JunIII's
Skunk Mani
DC header (JDM)
Hondata
2.5" Exhaust
But 204/141trq
B18c1
CTR Pistons
JunIII's
Skunk Mani
DC header (JDM)
Hondata
2.5" Exhaust
#43
Re: Let's see your 1.8L OEM Bottom-end, ALLMOTOR, 91 Octane Dynos (Spec R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spec R »</TD></TR><TR><TD CLASS="quote">http://i23.photobucket.com/alb...h.jpg
1 Post
Re: (jello24)
This is Omni's 1595cc 91oct B16 project from 9/03 that we fully documented.
-Mike@InterTune.Tv
Full Mod List and all sponsors are on the website! Since this is a 91
octane dyno post, thought I would put this up here. It would be
interesting to see what could be done in the future to push this
envelope further For sticklers, this is what the car made
on Bubba's dyno.
More info in the sig good numbers guys!
~my bad on this not being 1.8L...
Mike
http://www.intertune.tv
Modified by MikeSarr_GSR at 5:23 PM 7/27/2005
#46
Re: (MikeSarr_GSR)
here is mine
USDM Type R bottom end (stock)
Si head all stock internals
Type R IM
SI TB
DTR 2.0 ltr header (bought it before i got the motor)
Hondata
STR cam gears
filter on a stick (generic)
Hondata phenolic spacer
tuned by ED at Balanced Performance in Atlanta
Modified by Surubasi00 at 9:30 PM 7/27/2005
Type R IM
SI TB
Hondata
STR cam gears
#48
Re: (LsVtec92Hatch)
that's ed for you...I have seen some pretty damn flat A/F ratios come out of his tunes...and they all make good power...he know's his stuff man
Dave
Dave
#50
Re: (dwnthehatch)
Good numbers from everyone. My GSR is about to get JDM ITR pistons, fully built head and RM M22 cams/valvetrain. I'll let everyone know what it does from it's current 186whp/136tq
