Help with poor mans type R build!!!!!
well i have this build in mind and pretty much everything ready but lmk what you guys think and what numbers i can get!!!
HEAD B16 eldebrock intake manifold victor x 68mm throttle body supertech dual valve springs supertech titanium retainers skunk2 tunner series stg 3 cams skunk2 adjustable camgears BLOCK B18c1 bored to 82mm civic type r pistons acl race bearings arp headstuds micropolished gsr crank TRANNY b16 tranny act stg 2 clutch kit lmk what you guys think and what i can expect from this setup |
Re: Help with poor mans type R build!!!!!
Sorry but you are going about this the wrong way.
There is no way anyone can tell you how much power a engine will make based on a parts list. Perhaps, you should 1st determine how much power you are looking for then search the dyno thread at the top of this forum to get a ideal of how engine is configured. |
Not bad, i would ditch the CTR pistons for some ITR. And maybe look into a ITR style manifold or a performer-x.
My freind has the same setup except with ITR pistons! If it were low compression on boost be bad ass i told him! He agreed and now makes little over 320 to his wheels. But any how his all motor pmr was alright but not fast enough, he was always getten smoked. Estimated 180-200 with slight mods on these pmr arent that quick to me unless you fully built it allmotor tune on ITBs.
im aiming for 200 whp anyone else??
Hey bro if thats what you want rip it up! Remember its what you love.
If you spin the motor up and utilize the cams properly ie. getting them degreed and tuning the engine/ecu, 200hp is possible. The other question to be asked is what is this car going to be used for. Drag, autoX, or just street? Torque should be something else you go for if your using it for anything but drags. Torque will make the car more drivable and fun on the streets.
Originally Posted by cesarem1
(Post 41337995)
Originally Posted by mar778c
(Post 41334316)
its going to be a daily driver i just wnt something fun to drive and it will be in a 00 civic si shell.... so u guys think 200whp can be done easily with this setup..
do what mar778c told you to do and you'll know.
(Post 41333728)
BLOCK
B18c1 bored to 82mm civic type r pistons |
man i built an all motor poor mans type r....made 208whp here are specs...
HEAD: - Zex 903 dual valve springs + titanium retainers -gsr valves -Skunk2 intake manifold -Type -R throttle body - 440CC injectors -Type R cams - Password JDM Whale Dick intake -Blox throttle body spacer -Greddy trust Headers BLOCK -B18C1 stock bore -CTR pct pistons -Type R rods -Type R crank -Type R oil girdle -Type R oil pump -ARP head studs -ARP Rod bolts -ARP main studs I built the motor and sold it to a buddy after i had only put 1200 miles on it and its now in a Real JDM front type r...he is the one that dynoed it and told me the numbers..i will see if i can get a dyno sheet from him for you...hope i helped a little |
koo
I am doing a poor mans type r also.
So far I got b16 head stock Ctr camshaft Gsr bottom block Might be looking to get good hp on spray 75-125 shot(200-280) For track only. Need help with what size bore should I go? What kind piston? What kind and size rings? Crank? What kind retainers? B16 or gsr head studs? It's going into 2000 civic si. |
Originally Posted by Em1weksos559
(Post 50276242)
So far I got b16 head stock Ctr camshaft Gsr bottom block Might be looking to get good hp on spray 75-125 shot(200-280) For track only. Need help with what size bore should I go? What kind piston? What kind and size rings? Crank? What kind retainers? B16 or gsr head studs? It's going into 2000 civic si. Search. Read. Learn. |
