help with gsr/skunk2 T2 cams, no degree wheel
#51
Moderator
Re: help with gsr/skunk2 T2 cams, no degree wheel
You can't go from Type Rs to super aggressive cams like STAGE 2s on a turbo car without some dialing in and some dyno tuning.
It may not be engaging (all mechanical issues accounted for) because the cams aren't dialed in with this large turbo and bad backpressure issue.
Your turbo is not a 70 "trim". that is a different calculation all together. you need to measure the following components.
This is actual "trim"
#52
Thanks for the imput. i did find in Evans forum that the problem is the turbo manifold. so i have to remove them cams. i don't want to redo down pipe and hot side charge pipe. ill try to sell them or trade them for type r
#54
I try tuning but cant because it breaks really bad. I think the guys here are right and even i found a archive post saying that this cams need full lenght manifold. I have to believe this because my car was running perfect before i swap the cams.
