H22 Going lean at high RPM
#26
Re: H22 Going lean at high RPM
sorry for leaving the discussion. I was starting to get a rough, fluxuating idle after a while. I started driving the car like a granny because i was afraid of it leaning out. It started running leaner at lower rpm until one day, i got pissed off and abused it. I fed every gear to redline, power shifted the sh*t out of it, and it ran like a champ. It DID NOT go lean once and the A/F ratio was fine after it at idle. So i dont know if this is a faulty dyno wideband or what. I have never experienced the car going lean on the streets, only the dyno. With all that said and done, the car has been sold. I miss it. I bought an 04 TL, and regret it.
#27
i am having the same issues with my h2b set up. car made 216whp stock motor with plm header, skunk2 intake mani,skunk2 70mm tb, aem fuel rain, aem fpr, aen 320 fuel pump, braided steel line from tank to rail. car is fine for a few pulls on dyno then starts to lean out around 5500 rpms. car was also doing this when i had stock injectors, rail,lines and 255 walbro. any kind of response would be greatly appreciated!
#28
Thread resurrected.lol
What are you using for tuning?
I experienced lean WOT issues (~14:1 at 5.5k rpm) whilst on a stock JDM P13 with just the usual H22A boltons, but with Crome, a known decent wideband sensor, a dyno and a good tuner there should not be any reason to have lean spots in the tune.
#29
I am useing crome. I believe it ia leaning out at 5500rpm at like 15.8 or maybe little less.. The car will be fine for a few pulls then starts leaning out on its own. My tuner said he is stumped. Once it starts leaning out he adds fuel and nothing change. I believe he said from 60-100% duty cycle on the injectors nothing happens. If anyone has any suggestions please let me know. I have changed wire harness twice, injectors twice added grounds. My number is 4016549777 if its easier to communicate
#32
I have a jdm h22a set up as a h2b in a 93 civic hatch. h22a long block, gsr transmission, 70mm skunk2 throttle body, skunk2 intake manifold, plm tri-y header, 2.5 inch skunk2 exhaust, aem fuel rail, aem regulator, aem 320 fuel pump, 370rc injectors, bigger (not sure on size) braided steel fuel line from tank to rail. tuned on crome. car leans out once vtec engages. I do not have a drop in fuel pressure
#34
I have a print out of my dyno sheet if that would help, when I made 201whp with stock rail, injectors and stock fuel system except a 255 walbro fuel pump. car astill leaned out when vtec engaged. I am looking into hondata I a, running low in funds trying to fix this issue. between new fuel system and dyno time I speny $810.
#35
he was in the middle of tuning the car on the dyno when the car started to lean out. if I recall correctly he said he tried adding fuel to see if it was the issue. he changed the duty cycle from 60 to 100% and nothing changed. (not sure if I am explaining that correctly) I do know that he was trying to tune it though
#36
Look into Neptune, find more @ Hrtuning.com.. you'll thank me later, i assure you.
It just sounds like a software issue, you're not running out of injector and the FP is no where near maxed.
#37
I suggest trying another software. Crome is a nice program for bolt on to stock stuff.. Its been well proven that the timing values in crome are off slightly as well as other glitches.
#38
#40
I have a friend who's had this exact problem before on his B series. his car on the low cam would run fine etc but as soon as it crossed into VTEC, itd go lean no matter what was done to the tune. Turns out that the end plug on the OEM rail was the culprit. Try a different fuel pressure regulator as Rocket suggested, make sure there is a washer both on top and below the fuel line from the filter to fuel rail.
#41
#43
Graph is hard to see, but ya, i see like 14.9?
Have you changed your fuel filter lately??
Tou's idea is good to, that plug sometimes does cause weird things.
Another good idea is to try another good ecu, sometimes the injector driver might be bad?.. throwing out ideas.
Also, Neptune+Demon is like 399.00, does everything hondata does vs 695. If he has the "chip" version, then he's a neptune dealer. I'd try using that..
only thing i can think of is you really dont have 370cc injectors and still are on 290's. If i recall 290's are good to around 190-200whp or so..
#44
I don't know much about crome, and data-logging. I know it's possible with the HULOG interface, but a good full throttle to fuel cut pull while logging would more than likely be all you need to diagnose the problem if it is in fact not any of the issues suggested above. However, I do suggest moving over to a demon board (ectune, neptune) or s300 for more in-depth feedback from datalogs.
#47
#49
