CATCH CAN......
CATCH CAN......
So what should I look for in a catch can??? what qualities??? I assume the ones off ebay are garbage, but why??? Just tryna understand them more....let me know what you guys think
i don't think there's a difference other than how 'nice' it'll look.
depends if you want to shell out the bucks for a name brand unit or buy an ebay one instead.
i've got a Greddy one (square shape) and it was quite pricey after i bought the stainless lines as well.
Re: (pomansouth01)
There really is no difference, a lot of guys at the track just use an empty oil bottle. Not sure why you need SS lines just to go to your catch can, wee bit of overkill there.
cute little bastard
Re: CATCH CAN...... (revlimitcrx)
Depends what you're using it for IMO.
If its just to put between intake/valve cover, any one is the same.
If you're getting rid of the entire PCV system and switching to open breather system, Endyn/Moroso kits will be worth it and save you a lot of trouble.
Re: CATCH CAN...... (SkoundrelUSA)
i just used my power steering resevior
of course no power steering
Modified by alterdcreations at 2:32 PM 3/23/2007
yea it is for a NA setup... it will replace the black breather box on the block.. so yea i guess it will replace my pcv system.. so I should make sure to get one with a baffle??? what else should i look for?
what makes a endyn/moroso one better then the rest?????????
cute little bastard
Re: (revlimitcrx)
Kit comes with the replacement plugs for the block, hoses, clamps, filter, can. everything. And the can has a baffling thing inside it.
Re: (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">Kit comes with the replacement plugs for the block, hoses, clamps, filter, can. everything. And the can has a baffling thing inside it.</TD></TR></TABLE>
I wouldn't exactly call it a baffle, it's more like an opening with two small slits cut in it. It is better than all JDM cans out there, as they have no baffles at all, but really, it's not a baffle that is as significant as some may think.
FWIW, it's still a good and very complete system, as I ended up buying about a half dozen of them...
djtrini
06-22-2007 01:51 PM
