can we get a official b16 all motor dyno thread
yea i was wondering what you guys are making with yall b16
im running a 2.5in custom cold air
hytec small tube header with a test pipe
custom 2.5in exhaust piping
i got the stock im port and polished
dynoed at 145whp and 104wt
Re: can we get a official b16 all motor dyno thread
well i was thinking should i get a itr throttle body and did the headgasket really do any improvements
2 years ago i had a sir2 b16 with s2s2's, dc 4-1 jdm header (ran open), jg 65mm tb, aem cai, and ran it on an s200 with type r base map. It put down 177whp and 119wtq uncorrected.
This is such a general question, but here we go.
In 2001 I had a b16a2, S2S3's gears and valve train, Cai, Fpr, Comptech Header, S2 IM, S2 Ecu.
Dyno'd at 159hp 119ft lbs.
I believe there is a thread with all motor b16's.
friends b16a2 that i built had ctr cams, pistons, hytech rep headers, short ram intake, 310 cc injectors, skunk works intake manifold put down 170 whp on the dynojet
ITR head w/ headgames valvejob
bc3's, rm valvetrain & valves
60mm tb, p30 manifold
3' intake w/ pr velocity stack and k&n filter
1st gen b16 block w/ os pct's
edelbrock header, shortened, w/ 2.5 collector mod
smsp 200 cell cat, 2.5 exhaust
tuned w/ BRE
167whp/116wtq
tuned w/ BRE
167whp/116wtq
Enough. Why do d series guys hate b16's so much.
When I did my first b16 swap there wasn't much info out there for d series builds and at that time b16a changeovers were only $900. So naturally that was the cheapest, easiest way to gain 50hp and a great trans. That original b16 lasted me 8 years without even a hiccup. I sold that to a friend 2 yrs ago who still runs it today and he is HARD on everything he drives. Still no problems whatsoever. All this while still getting 30mpg consistently.
It may not be a power house but after all this time I have much respect for the little b16. I don't care that your D series was cheaper or that you beat them @ the drag strip. There are lots of them available and are very affordable so naturally people will build them. You don't need to criticize everyone who does.
/Rant.
/Rant.
Please quit cluttering this thread with senseless bullshit. No one in this thread is criticizing you for building a single cam. You are entitled to your opinion but remember this is a technical forum and you are in no way contributing to this thread.
I made 178hp@10,000rpm with a standard bore b16.10.5compression, s2 pro 1, edelbrock manifold,s2 68mm tb,rage header
thx everyone and i have an em1 that i can work with if i could i would go k series but with the way the economy is going its either k series and have no roof......
but thx everyone and also i can have enough fun with my b16 anyway so is there anyone else would like to share
B16a2 Head
B16a SIR1 Block
Stock IM & TB
PCT Pistons STD (CTR)
Skunk2 Tuner Stage 2
Cheap 2.25 Header
Custom 2.5 Exhaust
Crome Pro
169 whp 115 wtq
B16a SIR1 Block
Stock IM & TB
Cheap 2.25 Header
Custom 2.5 Exhaust
Crome Pro
169 whp 115 wtq
i was referring to D series due to there being so limited on increasing displacement, though i think for the average user building an NA F series (accord f series) is also not such a good idea... bisi has pretty much custom everything, you would poop yourself if you learned how much his crank alone cost
