Can a GSR manifold out perform a Performer X?
#52
Re: Can a GSR manifold out perform a Performer X?
i am interested to see what the gsr manifold can do because i am doing an lsvtec with a gsr head and ive been debating to use the gsr manifold and modify it or use an edelbrock victorx
#54
hmm okay... we are using a victor x on my friends b20vtec with gsr head and skunk2 stage 2 cams and cam gears it feels like it wants to pull up top like crazy but it honestly makes really good tq and good top end no dyno sheets yet, but it made more power over the gsr manifold for sure just by *** dyno i could totally feel the difference
#57
Something with a 85mm or 86mm bore and a 95mm or larger stroke at 13:1 or higher compression would work well with a Victor.
Most 84x89 2.0ltr do not move enough air to take advantage of a Victor. The Perfomer X Kingmotorsports modified is probably the best for 2.0ltr engines at this time.
#58
Victor-X on 99% of 2lt or smaller engine make them fell very sluggish under 7k rpm even if the dyno says differently. I find most 2lt combo's very sensitive to inlet manifold tuning, on a DD engine I find a well ported P30 manifold gives you the best feel.When I was running a 13to1 comp B18 I used both the GSR manifold modified and a S2 Pro series and the GSR gave the best power average but the S2 was much nicer to drive everyday.
#59
I happen to like my victorX, i dont feel any "sluggish" under vtec. The low / midrange in the car seems fine to me... but you need a serious motor to accommodate this manifold..
I would think a modded performerX or something along those lines would be better.
#60
#61
The manifold is schedule for delivery today. FINALLY!!
Some measurement I plan to take.
Stock GSR Plenum volume.
New Modified GSR Plenum volume. (Is has been increased, but not sure how much)
Performer X Plenum volume.
As well as the runner lengths in all of these.
#63
#64
NEW PLENUM SECTION, MUCH LARGER NOW, ROOM TO BREATH
OLD PLENUM
BUTTERFLY PLATE WITH NEW RUNNER ENTRANCE, EXPOXY
OLD BUTTERFLY
NEW BUTTERFLY RESHAPED AND SMOOTHED RUNNER TRANSITION
OLD MANIFOLD, TRANSITION FROM PLENUM TO BUTTERFLY SECTION YOU CAN SEE INTERFERENCE
THE PORTION REMOVED
I didn't take any pictures of the runner section because nothing really changed. Just smoothed and partially polished.
OLD PLENUM
OLD BUTTERFLY
THE PORTION REMOVED
#66
What would happen if you would remove all the material from the middle of the GSR intake manifold and add a 70MM throttle body? ? And OH_1fstgsr can you post up more detailed pics. Or just more pics.
Thanks
Remove all of this.
Thanks
Remove all of this.
#67
This would be very bad for air flow. You would be creating a ton of air turbulance.
As for more pictures and can no longer take the butterfly section off the plenum. They are epoxy’d together. What kind of pictures?
#69
You would have more Plenum volume which is good but you will have air trying to flow into a butterfly plate that looks like this.
I think i explained my self wrong. Remove the webbing inside the gsr mani. Look t my pics and the stuff inside the box is what i want to remove? gut the mani lol.
Its aight.
#70
1st, you will lose all the benefits of a dual runner, the low end torque.
2nd, the plenum volume would be huge, my guess nearly Victor X size.
3rd, from other manifolds that I have seen this done the runners are way oversized and slow down the air. Also the entrance to the runners is very poor.
From the research and studying I have done about manifolds, I would personally recommend against this. You basically are creating a Single runner manifold, and very poor one at that.
**EDIT**
After some thought on this request it might be possible, if you have some time and money.
Cut out the plenum section. Do not try to cut up the butterfly section. Get a shop to make an aluminum spacer, 1/2" or 3/4".
Now the challenging part, you then would be able to cut out the runner section. Most of what you cut out will need to be replaced with new velocity stacks and aluminum material to shape a taper to the exit of the runner section. Something like that picture below. NOT cheap or easy. It could be four separate pieces or one large piece that includes all four runners.
#71
There are a number of issues.
**EDIT**
**EDIT**
Thanks
#72
That makes sense. I know **** to none about intake manis and i have a spare one to experiment with. I will end up doing what you did. I was also thinking of using two butterfly spacers. One with butterflies and one with out them Just gut the inside webbing. Like top of the manifold, gutted spacer, butterflies spacer, lower manifold. That would give a tad bigger plenum volume? Also what do you think about a 70mm TB with what i said?
Thanks
Thanks
