'Budget' LSVTEC CR-X dies!... 89x85 B20VTEC rises from the ashes! **PICS**
#28
Re: (xD***tonesx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xD***tonesx »</TD></TR><TR><TD CLASS="quote">Derrick Robinson and his daddy blowin **** up like big dogs </TD></TR></TABLE>
What happened to your user title and avatar, Dickie?
- Derek
- Derek
#32
Re: (goforbroke)
<u>UPDATE:</u>
The car saw the dyno yesterday.
The final numbers were 200.7whp and 148wtq.
A gain of a solid 20whp and 19lb.-ft. were realized from simply an increase in displacement. Also, the powerband moved lower in the rev-range compared to the 1.8 setup.
I'll post the dyno sheet up later, with a comparison of the two setups.
- Derek
- Derek
#39
Re: (goforbroke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by votoms888 »</TD></TR><TR><TD CLASS="quote">Did you need to machine the rods to fit on the RS Machines pistons?</TD></TR></TABLE>
Nope.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goforbroke »</TD></TR><TR><TD CLASS="quote">So pop's car is going to smash your car even more now.</TD></TR></TABLE>
Hells yes.
The car went 12.75 @ 107mph on a bogged launch with 181whp.
I finally got the chance to drive it this morning. Dear God.
- Derek
Nope.
Hells yes.
- Derek
#40
official honda whore
Re: (D-Rob)
wow impressive, i guess not resizing the rods was a good/bad thing, you realized it is something that should be done, and now his car is even more badass!!!
now he should upgrade that header and go with a cam similar to yours and he will have a MONSTER of a crx
#47
Re: (votoms888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">sleeves WILL crack!!! SOON....very SOON!!
85 mm is too much on a b20 block without sleeving and even with a block guard
Here's to hoping you're incorrect, then.
- Derek
- Derek
#48
Re: (D-Rob)
Do you think that chamfering the rod journals on the crank would help out when using a 95mm crank. I was thinking that with the extra oil for the rod bearings that it may reduce some of the extra stress put on the rod bearings from the stroker crank. What do you think?
#49
Re: (frostyrb)
I'm sure it wouldn't hurt, but I doubt it's going to significantly increase bearing life.
95mm is still going to be putting a pounding on those rod bearings.
- Derek
- Derek
