Leak from small coolant spout SK2 Mani
Old 12-20-2009, 04:11 PM
IntegraGSR1999's Avatar
Default Leak from small coolant spout SK2 Mani
Hey guys, I am having a bit of a weird issue. The small secondary coolant spout on the back of the Skunk2 GSR Intake Manifold is leaking. I first tried to plug it up when i first installed this with a vacuum cap and a small hose clamp and it seemed to work fine. Recently it started to leak so i replaced the vacuum cap but it still leaks. I wanted to know if I could run a brass "T" fitting to the coolant lines that flow through the Throttle Body? Would that work? If anyone has any other suggestions it would be appreciated. Thanks
Old 12-21-2009, 08:41 AM
Skunk2Brian's Avatar
Default Re: Leak from small coolant spout SK2 Mani
That is actually the best way to install that manifold. Run a short hose to a T fitting in the line that feeds the Fast Idle Thermo Valve on the bottom of the throttle body. That way coolant is flowing rather than building pressure behind a plug. This should remedy your leaking issue. If you have any more questions about any Skunk2 products give us a call at 951.808.9888.
Old 12-21-2009, 02:41 PM
Okay but aren't the FITV's only on OBD1 vehicles. Mine is a 99 GSR so its OBD2. I was thinking to run a T fitting and a short hose to the "IN" coolant line that circulates through the throttle body? Would that work?
Old 01-11-2010, 05:54 PM
okay I ran that small hose and used the T fitting into the existing throttle body hoses and i thought that would fix the issue but its still no good. I'm not spewing coolant but there is a small leak after a bit of driving. Anybody have any suggestions to fix this. I don't really know where to go form here. Thanks!
Mr.Merz
14
09-05-2016 07:53 PM
kyle-Lst
16
05-08-2007 10:00 AM
StolenTeg
11-14-2004 01:08 PM
B18 CYA
06-12-2004 12:08 PM
IntegraGSR2000
01-18-2002 06:14 AM
Quick Reply: Leak from small coolant spout SK2 Mani
