B20z2/VTEC Build !
#27
Re: B20z2/VTEC Build !
Hey guess well I just got a smoking deal on a 98 CRV B20z2 Block $150. I'm currently shopping for parts and having the machine shop prep the block and crank. My goal is to hit 210 + whp.
Block:
98 B20z2 Decked,Honed,Hot tanked
Balanced and Micropolished B20 Crank
Stock B20z2 Rods with YCP ITR Spec Pistons 84mm (11.9:1 CR)
ACL Bearing
ARP Studs all around
Type R Oil Pump
Type R Water Pump
B20 Crank Pulley
Head:
'99 Civic SI B16A2 Head Stock for the meantime
Stock Cams
Blox Cam Gears
Hondata Intake Manifold gasket
Blox Racing 66mm TB ( Not Installed need TPS )
Precision 440cc injectors
Walbro Fuel Pump
B&M Fuel Pressure Regulator
Integra GSR Megan Header
OmniPower Test Pipe
Apexi WS2 Exhaust
Chipped P28 ECU / Hondata S200
Tranny:
00 B16A2 Tranny
ITR flywheel
Exedy Clutch Kit
I'll try to post pics of the build when ever I get a chance right now i have the block and crank in the machine shop getting worked on so hopefully i can get some pics? Hoping to hit 13's on a 96 Civic Ex Coupe.
What do you guys think?
Update some pics what the motor look like for now....
Attachment 474073
Attachment 474074
Attachment 474075
Attachment 474076
Attachment 474077
Attachment 474078
Attachment 474079
Attachment 474080
Attachment 474081
Attachment 474082
Attachment 474083
Attachment 474084
Attachment 474085
Attachment 474086
Attachment 474087
Attachment 474088
Block:
ACL Bearing
Type R Oil Pump
Type R Water Pump
B20 Crank Pulley
Head:
Stock Cams
Blox Cam Gears
Walbro Fuel Pump
OmniPower Test Pipe
Apexi WS2 Exhaust
Tranny:
00 B16A2 Tranny
ITR flywheel
Exedy Clutch Kit
Attachment 474073
Attachment 474074
Attachment 474075
Attachment 474076
Attachment 474077
Attachment 474078
Attachment 474079
Attachment 474080
Attachment 474081
Attachment 474082
Attachment 474083
Attachment 474084
Attachment 474085
Attachment 474086
Attachment 474087
Attachment 474088
#28
I have 1992 Honda civic EG lowest 2 inches,Full aftermarket susp, arms t arms with 01 B20Z2 Swap Skunk Pro sere throttle body, Skunk 84m throttle Stage3 6 puck 400 hp whip cutch kit GS2 5speed SIR Transmission Head exhaust 2.3 inches lowest long wide straight 3' wide.. P28 chipped damn pretty fast My girlfriend scary that things LOL
