B20/vtec Rod choice.
Hello, I'm about to start putting together my B20/vtec for my hatch. I don't plan on sleeving the block, I want it to be a mild all motor build. I want to use an after market rod but don't know who to go with, I've been looking at Eagle and Brain Crower. Also biso-moto seems to make a sick rod. I'm just looking for input from people who have used these products, or has any better recommendations. Thanks. :wiggle:
Re: B20/vtec Rod choice.
Sleeving B20 > aftermarket rods for B20
Originally Posted by bambam
(Post 43659725)
A block guard will be sufically if you plan on staying under 260whp.. b20 sleeves are strong in themselves as long as the motor is properly tuned. I run GE rods in my own b20vtec, however scat,ge, crower all make great rods. |
Originally Posted by ALL M0T0R
(Post 43659951)
Believe it or not, some places charge extra to sleeve a b20.. not alot of people carry the correct machine to sleeve b20's.
alot of ppl still swear by block guards i personaly havent used one
Originally Posted by 95skunkedgsr
(Post 43669399)
(Post 43669413)
I have a GE block guard installed by DonF. its about a half an inch down under..cools fine and no problems.. alot of people get mis informed about block guards..
(Post 43669413)
i went with eagle rods and no block guard but then again im sure im gonna be way under the 260 hp mark i should be right at the 200 whp mark and its a daily driver so not much harsh abuse will be done to it. and if it wasnt for me using forged pistons to get the desired compression i wanted i would of just used stock rods
[QUOTE=em1pusha99;43658729]Hello, I'm about to start putting together my B20/vtec for my hatch. I don't plan on sleeving the block, I want it to be a mild all motor build. I want to use an after market rod but don't know who to go with, I've been looking at Eagle and Brain Crower. Also biso-moto seems to make a sick rod. I'm just looking for input from people who have used them[QUOTE]
How much power do you plan on making? |
(Post 43669413)
(Post 43671238)
Im not misinformed, I just don't like them for the reasons stated above. And you're lucky, if i EVER had one installed DonF is probably one of 2-3 people I would ever trust to install it.
I bet for a "mild build" a sleeved block and aftermarket rod is WAYYY over kill man.
Crower :thumbup:
Thanks for all the info guys, I've been crazy busy at work and have not be able to get on. Anyways I plan to only make no more then 220 whp. Should I still consider sleeving it? I'll be running skunk2 tuner 2's and je pist!ons.
Should be ok sounds like my setup I went eagle rods je pistons and skunk2 tuner2
^ nice what kind of power did you make and what Je's did you run?
im currently running MANLEY rods... best rods i ever had
I went Eagles on JE pistons with BC IV cams
215whp here.. Daily driver too |
Stock sleeves? ^
