B18C6 - After all the work, it's not making the power I think it should.
hi guys
have following setup
P&P head 230 cfm
titanium springs supertech etc new rockers everything new and strong
+0,5 intake flat, 0 exhaust
skunk2 pro2 cams (no degrees)
12,3 wiseco pistons 81,5
h-beam rods blueprint 5430
intake polished skunk2 black series throttle skunk2 70+
exhaust 4-2-1 bisimoto 60mm original
76mm full catback no muffler
Vtec 6k
redline 8,5 - than it begins to detonate
result only 222,8 crank
Where is the other 20-30 hp?!!!
P&P head 230 cfm
Vtec 6k
re: B18C6 - After all the work, it's not making the power I think it should.
Not supposed to use oversized valves with Pro2's, and you should also get those cams degreed for your setup.
If you're getting detonation in upper RPM that means something is off with the timing.
I'd want to see a picture of the Bisi header, but those are often crap for performance applications. Also what intake are you using, the Skunk2 ITR replica, or the Ultra Street?
intake skunk2 pro (probably replica I don't remember because I've been building my setup since 2008, almost decade)))
That's alot of air in there with the cfms in head, tb and the cat back and cams. You're not getting enough fuel at those rpms, what injectors and fuel pressure?
Re: B18C6 - After all the work, it's not making the power I think it should.
RDX injectors are 410cc and I think the OP meant 3.5 to 4 BAR of fuel pressure... which translates into 51.5 - 59 psi.
do u have pro3? ive measured pro 2 cam in vtec with std valves and there was not so much room, but enough for no vtv contact. so what cams do u have? pro2 cam sheet say not to use oversize valves
pro3 are on other build with +1 int and vtec vtv was 1,7mm space.
ecu is hondata s300
fuel is walbro 255
rdx are 410cc
pressure 3,5-4 bar (not psi)
we tunned it 2 hours and no more than 220+ hp
and after 8,5k rpm it begins to detonate.
May be 410cc is not enought, may be 100 octane is low for 12,3-12,5 rate. Or to put higher sparks. Now it is ngk 7
Header could be a much better design. You're definitely losing some power on that exhaust manifold.
Ultra street intake would also be an improvement. And again, I'd attempt to degree your cams but watch for V2V contact.
Need to fix your high RPM fuel issue.
then again the tuner should be able to tell you if you are running out of fuel. (provided they are worth anything)
all b inside my Rex will be selling out
all components are new only 700km, if someone wants smth - pm
Baddawg1991
23
08-18-2015 02:53 PM
xQB21x
12
06-08-2008 08:18 AM
