b18c5 bore questions
recently bought a c5 block. the guy before me droped a valve..
the cylinfer walls look alright just some scraching so i wanna bore it to get ride of them. i was wondering if i could get it bored to 82mm if it would be safe. i would be useing 82mm jdm itr replica pistons. about 11.5.1cr if not safe could i jus use a block gaurd too brace the cylinder walls up? dont really want to resleeve but if i absolutly have to i will this would increase my torque a little right cuz of the bigger displacment? |
Re: b18c5 bore questions (c5stunna)
The conventional H-T wisdom is that 82mm is safe on stock sleeves.
been running on 82mm bore with ITR pistons and Blox B cams for over 2 years now, and no problems yet. (Knocks on wood)
if your going to do that might as well swap crank and rods (all oem) like allmtr and i did as well see thread for details.... https://honda-tech.com/zerothread?id=2289121
Re: (ekBlackHatch)
Yup, get's you pretty close to a 1.9L https://honda-tech.com/forums/images/smilies/emthup.gif
