b16a2 all motor
heres my setup ive been wanting to ask you guys so here we go, i have a b16a2 and plan on upgrading to civic type r pistons standard size and same rods i have in there now (crower) , .After this i plan on buying a fully built b16 head to put on this setup would this setup be something like a civic type r motor b16b?
Re: b16a2 all motor (gsrjohnny)
Not really since the CTR motor has a B18c block...but its a start
Re: b16a2 all motor (B16b-EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b-EJ8 »</TD></TR><TR><TD CLASS="quote">Not really since the CTR motor has a B18c block...but its a start</TD></TR></TABLE>
This isnt too clear to me but the CTR has a b16b and its pistons can be put into a b16a2 just clay the motor for clearance. |
Re: b16a2 all motor (American.Graffiti)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by American.Graffiti »</TD></TR><TR><TD CLASS="quote">
This isnt too clear to me but the CTR has a b16b and its pistons can be put into a b16a2 just clay the motor for clearance.</TD></TR></TABLE> The reason i said that is because he asked ifit was close toa b16b...i said no because the b16b has the block of the b18cbg |
Simply changing the pistons is not going to give you a B16b. The cranks are different, the block is different, obviously the rods.....completely different motor. Is the OP just lookin for some "bling factor" or something?
Nothing like a CTR.
I'd resleeve it and throw some 85mm CP's in it. Maybe a B17 crank too. |
Re: b16a2 all motor (Aquafina)
The OP's idea would be a B16B inspired engine, but it still wouldn't be a B16B. True, the displacements are the same, and changing the pistons could bring the compression to being the same, but the rod-stroke is different as well as the reciprocating mass, due in part to the crank as clean rice stated. The B16B is a long rod B16. Fun in lighter body cars, but lacks torque to really move the little piggies like the 94+ tegs and 96+ civics.
Re: b16a2 all motor (-=Zeqs=-)
thanks for the all the tech info guys , im jus gonna leave this motor alone then with the 9:1 compression je pistons i have and buy a seperate gsr block and throw in some type r pistons, and a built type r head just for daily driving grinding .
