B15C2 engine rebuild and further mods
Hi Guys,
A friend of mine has a Honda City our here in India which came with the B15C2 SOHC Vtec engine. The car has clocked close to 1.5 Lakh kms and was not well maintained leading to premature engine life. It now needs a rebuild as his compression is down to 150 and car is emitting white smoke. He wants to now modify it to extract some extra juice whilst remaining in NA form. Have heard that the D16Y8 cams match this motor(pls correct me if wrong). What we have planned is as follows. 1> Upgrade Pistons to 76mm forged (stock 75mm) with stock rods, new bearings and rebuild the block. 2> Port the head and install better cams ( need help on brand and part nos available that will fit) 3> Install a stand alone Ecu. He already has a exhaust setup and a JDM style intake manifold. He wants the car to be a fast daily driver with no intentions to drag or race the same. Is the above the correct option or would you guys suggest something else. Also if possible can we make this motor into a D16Y8. What would be required to do so. Thanks in advance. Jignesh |
Re: D15B7 engine rebuild and further mods
No one to help ?:(
Re: B15C2 engine rebuild and further mods
K, first off forged pistons don't just fit on stock rods without mods.
For a cam, not cams...it's a sohc check bisimoto, crower, exospeed, zex etc. Whats a "JDM" style intake manifold??? |
I seriously doubt you're going to get much input on this engine on here. It's not an engine many people are familiar with.
I wouldnt waste the money on any SOHC NA build for street use whether in India or the US. just my opinion.
If you are aiming to get your odd engine to be like a d16y8, why don't you just get a y8 swap and build it like you want. That will solve your aftermarket parts concern and switch you to a better engine.
Originally Posted by JR_Integra
(Post 45985020)
Hi Guys,
I know sourcing parts for this shitty motor is a big pain hence my original question. "Also if possible can we make this motor into a D16Y8. What would be required to do so." If you guys need any specs/pics on my existing engine let me know the info you require and I will try and procure the same. Jignesh |
Originally Posted by viperjng
(Post 45985099)
Hi Guys,
"Also if possible can we make this motor into a D16Y8. What would be required to do so." Jignesh |
