ARP Bolt / Stud Torque Specs For B16?
Old 08-24-2007, 04:30 AM
Ninja Mike's Avatar
Default ARP Bolt / Stud Torque Specs For B16?
What are the ARP rod bolts' torque specs for a B16 in sequence:
-specs with lube?
-specs with oil for clearancing?
Also, what are the torque specs for the ARP head studs in sequence?
I mis-placed the spec sheet that came along with the products,
Searched to no avail; thanks,
-Mike
Modified by Ninja Mike at 5:43 AM 8/25/2007
Old 09-28-2007, 07:58 PM
freak86's Avatar
Default Re: ARP Bolt / Stud Torque Specs For B16? (Ninja Mike)
65 ft lbs with the arp moly lube
i think 75 ft lbs with 10-30 motor oil(not recommended)
i'd start with around 22(honda oem bolt start torque), then increase up to the above torques gradually. remember to torque in in the right order.
Old 09-28-2007, 11:08 PM
Chris Tune's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by freak86 &raquo;</TD></TR><TR><TD CLASS="quote">65 ft lbs with the arp moly lube
i'd start with around 22(honda oem bolt start torque), then increase up to the above torques gradually. remember to torque in in the right order.</TD></TR></TABLE>
for head studs in the spec sheet it says, to 75 then a little bit down it says for ALUMINIUM go with factory torque settings and it says 65... some people do more some do less. so yeah factory spec = 22 1st then 63 in the correct order always.
rod bolts torque to 41 with lube IF i remember correctly, dont remember with 10-30. I have a few sheets at the shop i'll try to get one tommorow if i can remember.
teggything
05-27-2009 09:50 AM
Benjithx
12-15-2004 01:29 PM
Louie_EM1
03-24-2004 09:51 PM
Quick Reply: ARP Bolt / Stud Torque Specs For B16?
