All Motor Factory Block GSR Dyno/Track Results
#29
Re: All Motor Factory Block GSR Dyno/Track Results
my tuner advises against it to be honest and havnet found one person to tell me to run 3inch, you can i personally will not at this point. While id love to rock an smsp hytech or real toda im broke as **** after not being able to sell my dam turbo parts or id have one of those amazing real non replica headers, i didnt plan **** out right so i know ive made mistakes
#30
Purpose Built
#31
The motor has GOT to breath, and there's still a ton of people who have yet to realize this.
#32
Purpose Built
Only header ive owned that gave a night and day difference in power with no additional exhaust mods
#33
Purpose Built
Closed minded I suppose?
#34
when are people going to learn that engines dont need back pressure??? This is why a lot of cars are tested with an open header. Unless you're worried about it being too loud, its not going to do anything but increase your power output.
#35
Stock ecu - with skunk2 1st gen manifold, dc header, stock exhaust made 155ish?? I didn't do the swap. Ran 14.5's and 14.6's , she was driving on nitto's. I tuned the car, it went 14.1's.
Its back on a stock ecu, waiting on a few things as she's going to be a test car for my stage 1's..that's all I'm changing out, is cams.. hoping to see if i can get it to make 180 or go 13.5's with just a cam swap and tune. I'll get a better header and exhaust once i feel I'm happy with what i can get out of it.
Its a girls car, had some dude messing with us a few nights ago with a G37 that had an exhaust, and he got strolled lol.
I have about 30 tunes so far, since the beginning of the year on just stock GSRs alone..they just wanted a little more pep.. more gas mileage out of the situation.. if anyone needs bins lemme know, their all on cromePRO. But its what i recommend for people on a budget or not a lot of money who are in need of a tune.
If i put stock b16's and stock gsr's together probably around 60 tunes if i had to guess, i had to get another disc drive to save them all. I'll probably do more tuning test towards the end of the summer, once i buy an actual Dynojet for my own shop and not have to use other peoples.
#36
ALLMOTOR since you say 3inch you got dynos with it on a stock or bolt on gsr?
#37
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/3%22-catback-exhaust-stock-jdm-h22a-dyno-2197695/
Read the entire thread.. specially 92typer's response.
https://honda-tech.com/forums/showth...%27%27+exhaust
https://honda-tech.com/forums/showth...%27%27+exhaust'
there's so more.
oops, ... more
https://honda-tech.com/forums/forced-induction-16/2-5-inch-vs-3-inch-custom-exhaust-comparison-dyno-graph-comparison-1530154/
there's a few more, but just.. too many to list.. the general idea is you want more velocity flow.. your header design will ultimate set the pace and tone of how the air will flow, these headers, like bisi, and what not with big curves actually increase air speed going around and then this helps create what we call, scavenging.
DonF was educating me on header design a few days ago, and he basically told me, you find all the hot spots in the header, and from there you cut and merge.. anything behind the collector of the header is what is restrictive.
there's so more.
oops, ... more
#38
Girlfriends JDM GSR in a 97 EX. BONE STOCK w/ lsd
I thought the 2.5 definetely would outflow the ws2, and it put 180 on a ws2 sumhow
#39
Purpose Built
If you don't belive it needs backpressure, than why pick the more restrictive size piping of the two?
#40
lsd is a night and day difference.. that's really the only explanation i can give lol.
Exhaust is going to move.. regardless. Exhaust is being pressed out.. its going to move...how well it moves and exits the cylinder is a different story.
You want the exhaust or expelled gases to exit the cyl as quickly as possible, but without pulling so much, that it pulls the fresh air through the cyl, while overlapping is occurring.
#41
Purpose Built
#42
Because i wanted a somewhat quiet exhaust on my car since i daily it and really figured 2.5 woudl do the trick for a while, seeing as i had the ws2 on a hytech rep and it seemed to choke it like a mother****er in the higher rpm. while a 3inch mite do ill run 2.5 for now since things have already been ordered man. im hoping for an increase atleast over the 2.36ws2 i had
#43
All "off the shelf" kits aren't measured by OD.. they are measured by ID. When you buy a off the shelf 3'' exhaust, its not really 3''. It'll be 2.75 or a tad bit smaller.
2.5'' exhaust will be 2.35 or a tad smaller.. unless you're going with a kteller or vrs piping kit, they wont be "true" measurements.
your WS was probably around 2.25 so going to a bigger exhaust will help...you'll be fine with a 2.5, but you will be limited when you start adding more mods as it will need to breath easier.
#44
Purpose Built
If anyone knows of a well working one let me know.
I feel its the best solution for you as well. You can either have no noise or no restriction at the flip of a switch
#45
Let me say this.. 1 or 2 correctly made resonators will keep the tone of the car down, while sounding nice.. your muffler is going to dictate tone as in, if it sounds like a pissed off wasp or not, whether its a N1 fartcan, or a solid flow master or magnaflow muffler.
Which lsd do you have? mfactory itr quafe?
#46
This is exactly why I'm trying to fabricate a reliable E-Cutout. I have yet to find a off the shelf one without bad reviews but I'm refusing to go buy and exhaust just to get pulled over
#47
e-cut out is the way to go, especially if you live in CA where the police pull over any lowered Honda or import with exhaust for that matter
#48
Purpose Built
Yea I've heard of both, and actually everyone I've researched, ending up leaking eventually.
If/when I do find a cutout, would you say put it right after the header? Or go farther down the exhaust for scavenging purposes?
#50
I think a mechanical e-cut out with an extension spring and some sort of steel cable would be best. I'm actually going to have my buddy (who is a fabricator) help me with this. If it works out I would be more than happy to share my results when done
