I need YOUR help! main/rod bearings
i have a 2000 b18b block, i need new OEM main/rod bearings, i have the numbers i just need to have them decoded.
CCCCC #'s off the b18b block
oil pump side[ <- B2 | 2 <- C | 3 <- C | 2 <- B | 1 <- [flywheel/clutch side
1 4 2 3 4 5
is this all the infomation i need to get my main/rod bearings? thanks
1 4 2 3 4 5
Re: I need YOUR help! main/rod bearings (aemcivic_02917)
huh? if they were the oem ones in there to begin with, look on the side of the bearings. there will be a color marked on it. the dealership will ask for it or they won't sell any to you. you MUST know which bearing came from what cylinder due to the thickness of the bearing. you can however, go with aftermarket like acl, where you do not have to worry about the colors.
christion
11-06-2006 08:25 PM
