84mm b16 itbs going for 230whp and 0ftlbs
#51
Re: 84mm b16 itbs going for 230whp and 0ftlbs
this looks intresting... would be intrested to see the final end product. I'm running a 83MM bore with a 87mm stroke on a B16 block... currently at 247 BHP.. could be higher but my injectors (B18C5 type R) are maxed out. gonna swicth to K20As to be on the safe side and do a retune... but not expecting much.
#52
nothing fancy. Running the engine with buddyclub stage 6 cams. bottom ends been reinforced with the golden eagle block girdle. yep the k20 injectors are used.. got them like about less than 100 bucks.
#53
I got lucky and piced up a set of id1000 for 125$ I just need the top hats and pigtails for them
#54
#55
ID1000 inj have nice injector & battery offsets and allow for smooth idle tuning @ lower duty cycles. As long as you have a tuner that knows how to set them up there shouldn't be any issues.
#56
some updates: got the tps for the wilson and welded the v band on, made a engine wire harness for it looks really nice will post pics later,mocked up throttle cable and made bracket. just waiting for headstuds and oil pump to get here to put the long block together
#60
I'm going in to the shop tonight to work on some things so ill have more pics and updates shortly
#61
Aww man I wanted to see the itb setup.
Won't the GE manifold be overkill for this setup and just shine up top?
#64
Putting it all together this week and locking the rocker for no reason other than not having a vtec solenoid. Because racecar
#70
So I got the head together and took it back apart. Cause I decided to Cnc port it here are the results. Lookin good now for some DD tech cams and ill be good to go
#75
What did you use for the finish on the port work? I have mine done but want to make it look something like yours. I didn't realize you could remove all the area around the guide
