b16 block with b18 head
Old 04-22-2010, 06:46 PM
lil98civi's Avatar
Default b16 block with b18 head
So im looking for parts to piece together my build and i found a cheap never ran b16 block sleeved to 85.5mm with a erl deckplate. I really wanted a c5 and go 84mm for a 2.0L but that b16 is at such a good price will the headeroff a c1, my type R head and everything just switch over??? Is the oil pan different?? trans should just bolt up just worried about the oil pan header ect
Old 04-22-2010, 06:48 PM
lil98civi's Avatar
Default Re: b16 block with b18 head
Also will a type R crank and c1 mains work in the b16 block??
Old 04-23-2010, 04:08 AM
perseverance's Avatar
i don't think the crank will work, as far as mains i think it depends on if it's a b16a or b block because b16b comes with block girdle as where b16a doesn't. Yes the head will swap right over. header will swap over, oil pan will work although u may need extra oil because i think it's taller to compensate for the block girdle.
Old 04-23-2010, 02:16 PM
lil98civi's Avatar
its a b16a block so i would need mains from a b16 and as for the crank are the journals a different size??
Project97EX
12-23-2012 10:19 AM
OUBob
09-11-2008 09:10 AM
da6jdmteg
12-15-2006 07:39 PM
xDicktonesx
08-06-2005 09:04 AM
xmd
11
12-17-2003 04:10 AM
Quick Reply: b16 block with b18 head
