4P H22 - 2.55L from Honda's original big block 4 cylinder
Old 02-06-2016, 06:43 AM
  #26
4piston's Avatar
Default Re: 4P H22 - 2.55L from Honda's original big block 4 cylinder
Originally Posted by 1991_crxsi
I'm excited about the new H series head development you guys have in the works. I have been on the fence between you and RLZ for a while. Do you guys want a test dummy to send you a head?
The first round of changes are already done and we are about to put it on the machine next week. Its a bigger valve than what we currently offer and some other tricks for a new hp here and there
Old 02-06-2016, 08:05 AM
  #27
PSI GUY's Avatar
Would the H22 shortblock with the 100mm crank be close in price in comparison to the B series stroker shortblock price or is it a bit more for the girdle modification. Just trying to get a ballpark on price.
Old 02-06-2016, 12:28 PM
  #28
4piston's Avatar
$3400 Like the B and K Pro kit if you want this setup with this long rod and short skirt piston setup
Old 02-06-2016, 01:05 PM
  #29
PSI GUY's Avatar
What about using a closed deck H22 block with a dry sleeve setup to save on some costs. Plus I know where I can get a closed deck block. My brother in law has a closed deck H22 with dry sleeves well over 500whp for years now with no issues.
Old 02-06-2016, 04:52 PM
  #30
1991_crxsi's Avatar
Woa, that is a crazy good price.
Old 02-07-2016, 07:54 AM
  #31
4piston's Avatar
That would be fine. We just make the piston to the bore size that you need
Old 02-07-2016, 10:30 PM
  #32
Anti-GDD White Knight Simp
TracerAcer2.2L's Avatar
Whoa. How have i missed this thread. More importantly, why did bently coop or sleeper not tell me about this lol. This is amazing and I'm excited to finally see this happen
Old 02-08-2016, 08:03 AM
  #33
unusual71's Avatar
Would you say that to reach 400 the ports and chamber need to be welded? hard to tell from your pics but the piston dome looks like it is made to fit the h series chamber specifically eh? do you offer those pistons for sale or only offer in builds? it's hard to tell from the website i only see the wisecos listed.
Really great build, long live the H series
Old 02-12-2016, 05:21 AM
  #34
SpoonH2B's Avatar
What made you guys choose web cams over other cams??? I have never seen anyone using web cams fornallmotor so this will be interesting!!!!!
Old 02-12-2016, 09:08 AM
  #35
4piston's Avatar
It was a piston specifically for this build. For 400, more airflow, more camshaft. It will be another build with a little more $$ behind it before that happens
Availability and build schedule. We wanted to put a very aggressive camshaft in the engine, however the customer wanted a Pro 3. Pro 3s were out of stock, and they needed the engine to make a race. We try very very hard to meet or exceed build schedules...there is a lot of flim flam in this industry taking way too long on projects and dragging customers along. We pride ourselves in busting our asses to meet delivery schedules. We called Web and discussed a more aggressive cam that would still work with this spring and rocker setup, and they had cams sitting on our build table a few days later. Ironically we worked overtime and got the engine completed and then it sat here for several weeks waiting for pickup LOL!!!!
Old 02-12-2016, 09:23 AM
  #36
1991_crxsi's Avatar
Putting some money away. Does the shortblock come with anything on it like oil pump, Balance shaft removal, oil pan, etc? Also should you use these aluminum rods in a street build, or would we be better off going with steel?
Old 02-12-2016, 11:32 AM
  #37
4piston's Avatar
Just depends how much you plan on driving it. If its normal transportation to and from work in all types of weather, get a steel rod. If it is a car you are going to take out on the street when the weather is nice and you just want to cause a ruckus on the street from time to time...aluminum is fine.
Old 02-14-2016, 09:40 AM
  #38
SpoonH2B's Avatar
Luke do you know if they will share dyno graph or times at the track???? I want to hear their review in this set up.
Old 02-14-2016, 10:21 AM
  #39
4piston's Avatar
Im sure they will. The engine is on a boat now, but should show up soon
Old 02-14-2016, 10:42 AM
  #40
PSI GUY's Avatar
I picked up a block and a head the other day, probably get the sleeves put in this spring and maybe drop some stuff off when we are down racing this summer. Figure the next step for power is a stroker but I'd rather stroke the H than the B-series to make the most power that I can. What kind of labor to build the bottom end supplying your parts?
Old 02-14-2016, 10:44 AM
  #41
ESP.net's Avatar
Steel Rod you won't have to do as much clearancing since it will me much less wider. A Steel Rod will be able to do much bigger stroke then a Alum Rod. Common Sense.
Old 02-17-2016, 12:36 PM
  #42
OGlurker's Avatar
We don't keep them in all engines. We have plenty of engines that run fine without them. Honestly this engine could have run without them no issue in a drag race application with mild fuel.
We run squirters in endurance engines, and we have been putting them in some drag race engines that run very hot burning fuel additives.
If we build you an engine, we can get the squirters in there on a 92 stroke. Those little modifications are an example of us taking the time to go the extra mile for the benefit of the customer.
What are your thoughts with oil squirters and power? Specifically in that the oil squirters may create more windage cloud and drag? If the engine has very bad RS Ratio, would you recommend leaving the oil squirters? Have you noticed a difference in oil pressure with or without them? Thank you
Old 02-18-2016, 11:36 AM
  #43
4piston's Avatar
We build a lot of steel rod engines, and we tend to stay away from them on some of these very aggressive fuels that guys are using now. The huge cranks move the rod journal from an overlap position in relation to the main journal to an overhang position...its very hard on the crankshaft. The lighter aluminum rod is a lot easier on the crank when launching the car because of its weight and its shock absorbing properties. If this were a road race engine on conventional racing gasoline, we definitely would have used a steel rod with a weight greater than 470 grams.
We put squirters in an engine purely for temperature control. Most drag race engines we block the squirters off, but similar to my post above...some of these fuels get stuff REALLY hot. With that heat, you can swell a piston up in the bore on a single pass and scuff it to the point that the engine has lost a significant amount of power. So you run more wall clearance to accommodate this growth of the piston. If we can cool it down, we can run a tighter wall clearance and make more power for a longer period of time. If I'm building an engine for an IFO racer who will run FTW black, it will absolutely be setup differently in terms of clearances and oiling than if we build an engine for say....the new OGS spec methanol all motor class. That is one of the challenges of this fuel stuff...you can't optimize for BOTH. We have to find middle ground between building a nitro engine and building an all motor engine and it can be difficult.
Old 02-18-2016, 07:52 PM
  #44
kr3w108's Avatar
Hell yeah !
Old 02-19-2016, 01:19 PM
  #45
4piston's Avatar
I should add to that....we also use squirters on dry sump engines that pull lots of vacuum and we use different pins. big vacuum will suck the oil right away from the pin.
Old 02-19-2016, 04:52 PM
  #46
OGlurker's Avatar
Awesome additional information. Many thanks for coming back just to note that.
Old 08-04-2016, 08:50 PM
  #47
Pics are gone, along with my inspiration
Old 08-05-2016, 09:08 AM
  #48
1HGEJ2's Avatar
Awesome information 4piston!!! Thx for the Infos
Old 12-10-2016, 02:34 PM
  #49
1991_crxsi's Avatar
Any updates on this build?
bigplayj17
07-09-2012 12:23 PM
Nonio
10-18-2011 03:46 PM
Obama
Texas -OK -LA (Sales)
02-15-2010 03:10 PM
sprayinrice
02-15-2005 12:21 PM
H22aInside
01-06-2004 04:58 PM
Quick Reply: 4P H22 - 2.55L from Honda's original big block 4 cylinder
