240 whp 2.0 LS/VTEC. Done.
This is what detonation looks like and how it destroys a brand new fully built engine in less then 30 miles. Apon detonation, the head lifted up off the block, and blew metal into all 4 cylinders.
https://img268.imageshack.us/img268/...ture010nye.jpg https://img198.imageshack.us/img198/...ture005ygc.jpg https://img189.imageshack.us/img189/...ture007lxe.jpg https://img390.imageshack.us/img390/...icture001k.jpg https://img200.imageshack.us/img200/...icture011s.jpg |
Re: 240 whp 2.0 LS/VTEC. Done.
ouch. whats the plans now
What was the root cause?
injectors to small? fuel pump failed? fuel pressure n/g? bad tune? Fill us in, so others may learn. |
Boost FTW. Bottom end is GE knfie Edge crank, sleeved, Eagle H beam rods, everything excpect pistons are perfect, can still see the hone.
The reason this happened is becasue this store lied to and sold me 108 ocatane when I need 110 because he hates imports. So yea. Tune was great. Just the asshole who sold me the fuel. |
what was your setup and compression?
It also looks more like a dropped valve than detonation to me.
dump the pistons, buy a 895 dollar endyn head and an AFI kit and youll have a turn ket 500hp car, or a buckin bronco rodeo ride, however you want to look at it
Originally Posted by Teamdiesel
(Post 38763063)
Originally Posted by dlaub25
(Post 38763391)
X2
i dont thing the 2 octane point difference caused that since the points can vary up and down by a few, something failed in the motor like stated above
Originally Posted by TheRappist
(Post 38762893)
damm!!!
****kkk man, was it tuned with confidence?
Originally Posted by 1.5Slowmatic
(Post 38763422)
i dont see the head lifting enough with 240whp to allow metal from one cylinder to get to all 4. Did only one valve head drop?
(Post 38763412)
Yea, it deff did. We are looking into if it just dropped a valve, or dropped a valve due to detonation.
The pictures shown are of a motor which was destroyed due to a dropped valve.... |
man with all the engine failures i might have to get back into the engine building business, looks like most of the people that do it now just plain suck.
non claying bitches!!
Originally Posted by omniman
(Post 38765161)
Originally Posted by 98vtec
(Post 38765313)
Cook a chicken dinner in 15 minutes! |
Originally Posted by mtber
(Post 38765375)
Cam gears...??? SET IT AND FORGET IT!!!
(Post 38763487)
how would every cylinder have metal shavings in them when all they are all fine? Thats why we are curious about the whole detonation
(Post 38765403)
for only 3 easy payments and 19 dollars and 95 cents.
Back on topic.... Sorry to see the destruction of your motor due to a piston to valve or valve to valve issue... Could have also been a faulty retainer install etc. |
Again, what was your compression?
Sorry for your loss. If you post some actual details of the build we may be able to help you figure out how/why it happened so you don't do it again.
What cams? What valvetrain? What compression? Were v2v and p2v checked? |
Originally Posted by SuperTwinz
(Post 38765438)
Your intake manifold did that to the rest of the cylinders.
Excuse my ignorance...how? |
