Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Technical Forums > All Motor / Naturally Aspirated
Reload this Page >
2.5" vs. 2.75" vs. 3" Cold air! Advice needed! (Yes, I know its been covered)
Old 04-22-2014, 10:10 PM
Brandeezy1's Avatar
Default 2.5" vs. 2.75" vs. 3" Cold air! Advice needed! (Yes, I know its been covered)
First of all, I know this has been covered but I want CURRENT advice and recommendations.
So i'm looking to get a cold air for my dc2 made. Plan is to do a mild all motor build. Currently have a powerchamber intake. What do you guys recommend as far as size? I know a lot of factors play into the size so please explain what size is good for my set up.
Mod List as follows:
- B18c1 "gsr" motor
- Skunk2 Pro Series Intake Mani
- 70mm Skunk2 Alpha TB
- 2.25" Greddy 4-2-1 Header
- 2.5" mid-pipe
- 2.5" Spoon n1
Upcoming:
- Supertech Full Valvetrain
- Skunk2 Tuner 2 Cams
- AEM Fuel Rail
- AEM FPR
- 310 or 370 Injectors
- Skunk2 Alpha Header
- Portmatch Mani to TB
Let me know what you recommend. Thanks!
Brandeezy1 is offline
Old 04-23-2014, 06:45 AM
bluehbcivic's Avatar
Default Re: 2.5" vs. 2.75" vs. 3" Cold air! Advice needed! (Yes, I know its been covered)
Iit will never be covered to each engine his own intake tube setup, dyno test!
bluehbcivic is offline
Old 04-23-2014, 07:57 AM
93egSLEEPER's Avatar
3" pipe that is 18-24" in length seems to be a good overall setup to run. On 2L+ 3.5" seems to respond better. Get a BPi stack and filter for it and call it a day. Unless its a race motor where every .01 whp must be extracted keep it simple and go with what works.
93egSLEEPER is offline
Old 04-23-2014, 08:12 AM
whitesihatch's Avatar
3" with a velocity stack
whitesihatch is offline
Old 04-23-2014, 08:15 AM
Moderator
crazes's Avatar
its been covered, research and you will find the correct answer. Testing is the best way period.
crazes is offline
EKb18cDAP
05-06-2016 04:26 PM
Brandeezy1
12
06-23-2014 10:17 AM
Bedgoodmrb
12-18-2009 09:12 AM
99skunkedSi
09-09-2005 03:24 AM
Quick Reply: 2.5" vs. 2.75" vs. 3" Cold air! Advice needed! (Yes, I know its been covered)
  • Ask a Question
Question Title:
Description:
