p3000 code issues k24a1
I had a code to change the timing chain, just changed the timing chain, checked timing - everything lines up
https://files.catbox.moe/s9mihv.jpeg (picture of timing)
(p0341) when I looked it up, a common response was chain was stretched
vtc gear wasn't changed, stock spec
would a bad valve lash cause this? would the cam position when changing the chain effect the lash
now I have p0303 stored code ( flashing check light). car runs very rough, eventually dies
moved the coil pack from 3 to 4 and got 0302 (cylinder 2), so I got all new coil packs
back to p0303 stored
changed the crank angle sensor to an older one I have and now its p0302
I did the "dollar bill" test and the bill was flapping
takes a lot of cranks to start- could be due to failing starter
pulled the plugs- from left to right
1- half fuel fouled
3- fuel fouled
4 - fuel fouled
2 - extremely fuel fouled
put in a new set of plugs, cleared the ecu by grounding the positive and negative lines for 10 minutes ( off battery) and now code 0303
changed primary 02 - code 0303 pops about 1min into running , runs better but dies quicker
1- half fuel fouled
3- fuel fouled
4 - fuel fouled
