"Official" All Motor LS B18a, B18b - DOHC NONvtec
#1126
Re: "Official" All Motor LS B18a, B18b - DOHC NONvtec
Bringing up a old thread for those enthusiasts that like to fool with nonvtec headed engines. Looking for some pistons with a yielded compression ratio more than 12.3? Done a quick search cant find any. How ever only reason why I am asking, a couple years ago I almost bought a set of 14.1c/r Probe pistons.
#1128
Almost forgot about this thread. Occasionally I get PMs for things on this subject (my ported P8R and my 405A cams) -- but I think most people have forgotten all about this kinda power. I'm gonna go back a few pages and catch up to see what people were working on.
#1129
Sup guys, new to the forum. Looking for recommendations for rebuilding my B18B1 LS 4dr/Auto. I'm looking for a few extra HP while keeping eh reliability of the engine. Something simple/classic .
#1130
If anyone is still on here let's get some talk going again.
I have a simple all motor b20 build planned out for a weekend "drag" car, it's going to be in a really light crx hf, goals will be mid to low 12s. I already have the cylinder head done and will be using that for the build, it has a full port job by myself, crower 404 cams with vms cam gears, supertech single valve springs and retainers, the head is fitted with a ported b16 intake manifold but I will probably try to weld up another b16 intake manifold with a b20 manifold plenum for more volume on it, might try to play around with some itbs, either home made or obx, that will be down the road though. The bottom end will be stock rod with arp rod bolts and probably 85mm b16 pistons off eBay. I plan on finding any cheap b20 block I can that's build able and doing some moroso block filler in it for added strength. I'm hoping to make 200whp out of the setup at the least and will continue to make changes to it to get there. If I can carry 145 ftlbs to 7500 it should make just over 200whp. Goal weight for the car is 1700 or less with the driver. It will have a fuel cell up front as well as a small battery up front. No interior just seat, steering wheel and cluster zip tied. Cut out most of the sheet metal. Really excited for it. Should be a very budget minded build.
#1132
Zeal autoworks estimates it at 12.1 to 1 comp. I think that would be about border line for working on pump gas but it really depends on how the cams respond to it. I can play with cam gear adjustments to get the dynamic compression ratio to where it would run on pump just fine.
#1133
Just ordered 85mm b16 pistons today. Been thinking about the project allot, I think that having a larger plenum for this sized motor would be benificial so I'm gonna source another p30 intake manifold and I have a b20 giraffe plenum cut off already to put on the b16 intake manifold. I will port the b20 plenum and make sure the runners have a slight taper as well. Just need to source a tranny now. I was originally thinking a ls tranny would work well but now I'm leaning towards b16 trans since I'll be able to rev it to 8-8500 depending on when the power falls off and I'd like to run either 22 or 23" slicks depending on what I can get my hands on for cheap.
Anyone still on here building stuff? Post your builds. It makes me sad that the forums are dying 😭
#1134
#1135
I understand that very well. I've been tuning for a living since 2010 so I get to see allot of what works and what doesn't work. I'll put it together with the estimated cr of 12 to 1 and if I feel it needs more comp i can always deck the head or one ply the head gasket. Picking up a builder b20 block tomorrow with crank, rods and phk pistons for $100.
#1136
#1137
Bottom end is starting to come together. This is the first bottom end I've ever assembled myself. I don't know why it took me so long to dive in but so far it's really fun. Only issue I had was the one set of rings I didn't check gap on which was the oil spacer ring ended up being way to tight stopping the pistons from wanting to drop in. Gapped then and everything went together like butter. Using acl race bearings and all clearances are just about perfect.
#1138
Something I've been working on. 84.5mm b16 piston b20. 404's, custom built intake manifold for dual throttle bodies in a super light crx.
#1140
Let's keep this thread alive. Anyone have anything cool in the works they are building? this is my intake manifold, built from a b16 lower half and some 3" aluminum piping and 11gauge aluminum for the end pieces. Should have some videos of it running by next week at some point.
#1141
#1143
Definitely. I'm really happy so far. Went out last night after I got it running and did a bit of street tuning, drivability is great everywhere and the power comes on really smoothly. I was able to dial in a nice smooth idle at 875 too, so the setup remains nice and stealthy. I'm sure I will be leaving a bit on the table with my induction and exhaust setups, but it's worth it to me for a well behaved dd. I mostly just wanted to shift the torque peak up the range a bit and get the knock under control with this shitty California gas.
#1144
Yeah the idle like stock just a little louder. If you end up wanting it to lope you can adjust your cam gears for a little more overlap or run it lean at idle. That's one of the things I enjoy the most about cammed non vtec motors is the Lopey idle.
#1146
put the cart before the horse posting the P8R head.
The block that inspired it all...it was given to me by a friend. It had a damaged piston, but a complete bottom end with rods. I wish I took before pictures, definitely didn't look like this
Pistons & Rings have arrived.
#1147
What's the story on the missing cam cap on that P8R? I'd imagine it's worth north of $250 if it's complete, clean, and checked to be good to go.
#1148
touching my previous block post, the only before snap I have of it before cleaning
onto block guarding....so I killed a china block guard on install, I even shaved the protruding ledges where the headstuds are (uncomfortably so). After it distorted I went back in and shaved the ledges even more.
Then, I purchased a supertech B.G., it started off better, I was excited - it too got stuck. As you can see I messed up. Should I remove it, sand more and try again? or just deck the block and send it!?
I've installed at least 5 of these things...I did my buddies "china joint" perfectly....
#1149
Re: "Official" All Motor LS B18a, B18b - DOHC NONvtec (CW96)
Huh, cool idea. How about P8R information as well? I'll dig up some of the more pertinent threads later on and link them, if that's how we're going to be doing it.
B20 non-VTEC FAQ with P8R information
https://honda-tech.com/zerothread?id=1467903
Nonvtec.com...just because, I guess? The people there are at least dedicated to the non-VTEC cause
http://www.nonvtec.com/board
Discussion on making P8R head work with an LS block
https://honda-tech.com/zerothread?id=1466416
"Built" streetable B20 (RS Machines pistons, Crower 404s, etc.), piston and CR discussion
https://honda-tech.com/zerothread?id=1707713
If any or all of these are out of line, PM me and I'll remove whichever ones.
Modified by Stinkycheezmonky at 4:15 PM 9/25/2007
