Acura TSX Acura TSX Sports Sedan. USDM TSX and Euro/UK/JDM Accord.
Well got my jdm taillights installed
Old 10-27-2010, 08:44 PM
94rs-turbo's Avatar
Default Well got my jdm taillights installed
put mats or cardboard just something to protect bumoer from getting scratched on the ground
Also a DIY post
take clips off bottom first
if you have madflaps
under the flaps theres a screw
side upper corner screw
cap you can see with trunk open pop off easily 10mm under x2
theres a t25 torques bolt you dont have to take off but I did cuz didn't know
pull sides back slowly and carefully, clips come loose then pops off easily
3x 8mm nuts behind plastic cover and unplud the 3 light plugs
2x 10mm nuts on underside of light and whole reason you have to remove the bumper, black bracket holding it on
like the pic says
you will notie new lamps dont use the p-nut bulb so just leave it in you oem light
now reverse order and tell to make sure everything works and good to go
Old 10-28-2010, 02:17 AM
senser1080's Avatar
Default Re: Well got my jdm taillights installed
lulz you have to remove your bumper to change tail lights? what a pita, even if it takes like 10 min lol
Old 10-28-2010, 08:58 AM
94rs-turbo's Avatar
yah the last pic shows that black bracket with 1 screw holding it on because of that you have to do all that extra work so gay I know
Old 10-28-2010, 10:52 AM
94rs-turbo's Avatar
pics installed
Old 10-28-2010, 03:03 PM
BlueIntegraBoy's Avatar
Don't you miss working on the R?
Old 10-28-2010, 03:20 PM
94rs-turbo's Avatar
LOL course but I'm working on getting some things done to it. As long as I'm working on a honda, wether its friends on or mine, I'm getting my fill on working on cars
Old 10-28-2010, 04:50 PM
I just figure working on the CL9 is more work, such as removing more panels or a bumper to change tail lights.
Old 10-28-2010, 06:55 PM
94rs-turbo's Avatar
lol please you know reaching those 20 nuts on a teg is a pain as the plastic panel is digging into you arm then the nut falls and goes under you spare tire..... interior parts are more work but nothing too bad. acutally wiring up V1 radar in my buddies M3 was pretty easy and same goes for my GF's 08 5 series
Old 10-28-2010, 06:59 PM
I can attest to this many times
Old 10-28-2010, 07:32 PM
94rs-turbo's Avatar
lol knew it!! atleast theres only 3 8mm and you just take rectangle cover off to get these off
Old 10-29-2010, 07:34 AM
JunkyardGSR's Avatar
i love these, where'd you them and how much?
Old 10-29-2010, 09:26 AM
94rs-turbo's Avatar
I was lucky a guy 10 min away from me parted his car out, but either ebay.uk or heeltoe sells them but 06-08 style is $315
--FELIX--
05-25-2008 09:02 PM
happycorey
01-24-2008 07:22 PM
IMPORTEKNIKAICR
12-05-2005 07:19 AM
Quick Reply: Well got my jdm taillights installed
