socal :: anyone want to help me install OEM kit?
finally moved on from the prelude and got a tsx
i have an oem kit on the way and was wondering if anyone in the socal area would like to help me install! the instructions require me to remove both front and rear bumpers and since i've never done it, it'd be nice to do it with someone who has.
let me know! food is on me.
-jon
-jon
Re: socal :: anyone want to help me install OEM kit? (Jon Like Wh0a)
i can tell u how to remove it, very easy u can do it by yourself. jus take off the clip from the inner grille cover and clips under the bumper and the screws by the fender under the front tire and they come right off same thing for the rear also jus there are 2 bolts located by the trunk you got to open and you will see on each end a round plastic piece you gotta pop out and the bolts are in there to remove.
if i was local i'd help
its pretty simple
HOWEVER!
a MUST HAVE is an ALLEN KEY shaped phillips head screwdriver ( 90degree angle)
it will save you TONS of time vs removing your wheels!
its pretty simple
HOWEVER!
Instructions for installing oem optional side skirts and hardware necessary- ANY HELP greatly apprec
b18c-rDC2
02-26-2003 09:38 AM
