Overheating. Changed thermostat. Still overheating!
Hey guys. Recently, the car has been running on the hot side. After turning on the heat (at full power), the temperature gauge will drop back down to normal operating temperature within about 1 minute.
I just replaced the thermostat with an OEM Honda/Acura thermostat (with housing). It is still overheating! The car has 72k miles.
What could be wrong?
Thanks in advance!
Thanks in advance!
Re: Overheating. Changed thermostat. Still overheating!
I found the problem. There was a hairline crack in the lower radiator hose. I replaced it and it solved the problem!
was it leaking out of the hair line crack? im having heating problems and can figure it out.
be professional
Even if you have to pay someone else to do it, a pressure test can still save you a ton of money. Proper diagnosis is much better than throwing random parts at it.
That'll do it.
Glad to see you bought an OE thermostat, too. Aftermarket thermostats can often cause more cooling problems than they fix.
cbr_ryder
Classic Hondas
16
07-28-2023 07:13 AM
cbr_ryder
Classic Hondas
01-06-2022 05:47 PM
jald3rd
05-24-2016 12:11 PM
