my turbo TSX project
#180
Re: my turbo TSX project
This doesn't sound right at all.....
First, there is no way any tuner in the right mind would run the injectors at 100% duty cycle. That is asking for a blown engine. The most I've ran was 90% duty cycle and that was really pushing it. Typically, 80% is the reliable limit.
Second, your dyno graph is showing 356hp. You can make 356hp on 550cc injectors and that wouldn't even max them out. And you maxed out 1000cc?
#181
I'm going to be doing a K swap for my K20Z1 for the K24 and there is a company in N. Carolina that does custom builds for anything you want in a K24. They are very knowledgeable and honest about what you need and what you don't, according to you specific application. They sell an ECU specifically set up for the 24, turbo/no turbo, ust let 'em know what you currently have and what you're planning on doing and ust run from there bro. Hope they can help.-J
#182
Oh sorry if your interested I have the site and the number, just msg me. I'm new to this board and haven't had time to read all the stickies yet. And if I can post the name of the site just let me know, so everyone can take advantage. BTW I don't work for these guys, so this isn't a shameless plug. I live in So. Cal
#183
#184
#186
since snowboarding season is almost done its time to get back in the game. i will be taking out the motor this weekend. hopefully ill get my clutch in and i can install my temporary motor.
heres my temporary k24a4 motor untill i rebuild the k24a2 and yes i will be boosting this one too. lol. once you go boost you never go back.
#187
well today was a productive day. ordered my clutch on wed and got it sat morning. thanks to CLUBRSX. heres some updated pictures.
took apart the K24A2
more updates tomorrow. hopefully install the donor motor and get it fired up.
#189
i finally got her finished today. cant wait to get her tuned and break in the clutch. now its time to rebuild my K24A2 motor.
heres a short clip of her start up.
http://youtu.be/bx9UMZ8ooOI
#192
just got some of my fuel return system done. with this return system i should be making some more HP.
drilled a hole for the return fitting
i drilled a hole right through the "***" that is directly above the fuel pump and attached the black factory tube to the feed fitting and the *** as my fuel feed.
then the AN fitting with the blue fuel hose was connected to the bottom of the fuel
where the original feed was connected to.
epoxy is what i used to seal the AN fitting.
hooked up the new deatchwerks compact 265 pump and installed into tank. next will be the hook up to the fuel rail.
#197
same kit but this time ill have plenty of fuel and maybe some more boost lol. my A2 motor will be a rebuild for next year and my goal for that motor is 500HP. once you go boost you never go back. hopefully i dont blow the head gasket on this one too. "knock on wood"
#198
