Reset light
Does anyone know how to reset the maintance light for a 2001 Acura cl??
Re: Reset light
Sit in the car and insert the key into the ignition tumbler. With one hand, press and hold the select and reset buttons (to the right side of the gauge cluster) simultaneously. With your other hand, turn the key to position II ("on") so that all of the lights in the dash come on, but do not start the engine. The Maintenance Required light will turn on for a 2 second self-test, then flash off briefly, then turn on again. Continue holding the start and reset buttons. After about 10 seconds, the light will turn off. Release the buttons, and you're done.
