NEED HELP!!! 04 TL 6speed
I'm having trouble with my 2004 Acura TL the clutch was slipping so I replace the clutch and now I can't get it to go into gear I've bled and bled over and over and over and over and can't seem to get it to go into gear still. Does anyone have any suggestions on where I should look next? Should I change my clutch master cylinder? I'm at a loss please help.
Re: NEED HELP!!! 04 TL 6speed
Brute Power provides clutch products that not only meet the OE performance criteria, but also often include additional features to make installation easier and improve the part's durability. 100% of all Clutch products are tested after final assembly to meet all functional characteristics.
New Clutch Kits include the following:
BRUTE POWER/PERFECTION CLUTCH Warranty Information:
12 months/12,000 miles
- O.E.M. style cover assembly, computer tested for clamp load, plate lift, and finger height
- O.E.M. style clutch disc with non-asbestos facings built to exceed O.E.M. specifications
- Clutch release bearing meeting or exceeding O.E.M. specifications (unless otherwise noted in description)
- Pilot bearing/bushing (where used)
- Alignment tool for the perfect clutch installation (where used)
- Hydraulic Line Disconnect Tool (where used)
Yes I change the clutch out myself I am not very savvy I'm self-taught. I went off of instructions that came with clutch and a few YouTube videos. I torque the bolts to 10 lbs.
On the assumption the Brute Power clutch kit you used is simply a repackaged OEM clutch and pressure plate (made by LuK); on the surface it sounds like you didn't adjust the pressure plate correctly. The LuK pressure plate used in these cars is a "self adjusting" type; they are set in the factory, however, during shipping they virtually always "self adjust" all of the way out.
A few other comments:
- It is recommended you replace the dual-mass flywheel whenever you replace the clutch. If you don't, you'll be doing a clutch job again soon.
- There are a few different tools one can use to adjust the pressure plate, Amazon sells one for a little over $100. If you have a well provided shop you can fashion you own adjustment tool using a press.
ls95hatch
05-24-2003 09:34 PM
